Last Post: murphdog
0 Cam question
Last Post: T. Clark
Last Post: ericfreeman
0 strange noise in top end
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: 84rzv500r
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
electrical, wiring harness
Old 15th February 2009
shameless's Avatar
shameless shameless is offline
Sportster/Buell Model: XLH 883/1200
Other Motorcycle Model: Ultra Classic - Work Bike
Other Motorcycle Year: 2007
shameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to allshameless is a name known to all
Default "S" model specific Q&A
I want a place that we "S" owners can subscribe to so we can ask and answer questions specific to our model, and have them archived. We don't need a whole new section, just a thread that is easy to find and we can handle it from there. Most times if there is something specific we need it will be days before any other "S" owner sees it due to it being buried in all the other threads. I highjacked our "Who owns..." thread just so someone would see my question. I know a lot of us have it saved to welcome the new guys so it was more likely to be seen there. Thanks in advance.
Now for anyone posting here, if it's specific to the XL1200S model then it is fair game. Ask away but please stay on topic to keep the thread for what it is, information.
Happiness is a motorcycle. Nirvana is a long curvy road.
ReddTigger's Avatar
Sounds like a good plan..
Since I Have the "S" heads...
whats the best single fire ignition for the Dual plug heads ?
States I've Ridden in
71.3 hp 70.8 tq
shameless's Avatar
I'll move my Q&A over here now.
Where it all started.... http://xlforum.net/forums/s...&postcount=205
The bike is wired right so now what? I had the whole bike apart fixing the head so where do I start? It turns over but won't start.
radeschultz's Avatar
radeschultz radeschultz is offline
radeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of light
Redd, not able to say what is considered "best", but this link here has some real good info...
http://xlforum.net/forums/s...d.php?t=186027
Post #7 by Steelworker includes some leads on aftermarket ignitions. I wasnt sure that I liked the idea of giving up the map sensor and running the voes in order to utilize these programmable units, but I dont know if its that big a deal or not...
If you find anything to add please share
I replaced my ignition module and wires on my 1200S a while back and shared the experience here
http://xlforum.net/forums/s...d.php?t=310497
There is some helpful info I think, especially finding good wires that fit our bikes.
Old 16th February 2009
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Stuck the thread...as requested....good idea, BTW...
Shameless...PM me if you need any "editing" in this thread...
~Chuck
Occam's Razor...
XLF Tuning Stickies
shameless's Avatar
I take you up on that should the need arise. Thanks again BTW.
ReddTigger's Avatar
fortunately for me, I don't have a map sensor
According to their respective companies.. I sent an email with the same question to Daytona and Dynatek.
Daytona Twin Tec: You can use our Model 1005 with an appropriate coil, but it is not a plug-in. As far as we know, no direct plug-ins are available.
And Dynatek.Ignition wise, the Dyna 2000i would be the best choice for an ignition which will allow you the opportunity to tune for your motors combination. However, coil selection is more difficult on a Sportster due to space limitations. You will either have to adapt a custom dual coil mount for a pair of dual output coils, or, attemp to fit our DC6-4 Twin Fire coil. The DC6-4 coil is slightly larger than stock, but contains two (2) coils within that will allow for single fire operation in a dual plug head machine. It also uses the stock type mounting bolt pattern.
Streak70's Avatar
Streak70 Streak70 is offline
Sportster/Buell Model: 1200S - totaled 09/15/10
Streak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura aboutStreak70 has a spectacular aura about
Default Possible source of High RPM Sport Ignition modules
This was posted on the Yahoo HDXL1200S group in January, 2009:
These modules have all been purged from Harley dealers everywhere but
there are 67 (last inventory count) at Vintage Parts in Beaver Dam
877-846-8243. But they will only sell to franchised hog dealers. It is
the replacement module (module only) for the 7500rpm screaming eagle
kit. 32982-98 .
Streak70's Avatar
Ugh! I don't envy you. I guess the easy, basic stuff first, air, fuel, fire, and timing. Then pushrods in correct holes, cam timing, etc.
Wishing you well, hope you can get it together soon as spring is going to be here someday.
Sooner for some of us.
