0 Hello from Long Island, New York
Last Post: TheBreeze
0 BETTER Brakes for $214
Last Post: BWP 5p
0 Buy A new battery
0 Speed
Last Post: dewjantim
0 Deer hunting at stairman's.
0 On starting a new thread
Last Post: Yakcm2
Last Post: Yakcm2
0 Timing
0 Powerraythor conversion
Last Post: RKN
0 Blackstone HyperTek
Last Post: jump
0 69 oil pump breather timing mark
0 Cases Full Of Oil
0 What weight oil?
0 New users of Windows 10
Last Post: SLW210
0 Ural quality testing
Last Post: Edster
0 RSD Rear-Sets for '04-'13 Sportsters
0 Loose oil pump feed fitting - 2019 Iron
0 Vance and Hines RSD Tracker Exhaust
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
electrical, wiring harness
  #1881
Old 9th October 2019
ftwflh ftwflh is offline
Sportster/Buell Model: 1200S Sportster
Other Motorcycle Model: 1972 FLH
Other Motorcycle Year: 1972
ftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to beholdftwflh is a splendid one to behold
Originally Posted by DramaLlama View Post
Yeah I've noticed anything over 6500 isn't really making any power at all, so try to make sure not to hit above that for that reason also. I'm on the W grind also.
I have a set of SE536 cams going in this winter.Along with a set of S heads that are ported and flowed with bigger valves to match close to XB heads along with a set of fresh cylinders set up with thunderbolt pistons.All thanks to Chad Hart of XLXBHorsepower.
I should be able to hit the 7000-7200 and still be in the power.
BTW my times with just the 7500 module and S&S Super E are 13.56@98.2 mph best and avg 13.77 @ 96
1998 1200S Sportster, 1972 FLH,2003 Vrod,2011 Victory
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
Anyone had many vibration issues with the 7500 module? If I ever got close to 7000 RPM my speedo would mess up and start reading about 30mph too low until I came to a stop. Recently the speedo just stopped working completely after running the bike hard.
I killed my speedo that way(I suppose). It would read either 30mph under or the needle would just bounce. I replaced it with a Dakota Digital MCL3200. I had to solder a bunch of wire together. Although the line to the Speedo sensor was plug and play.
Sent from my LM-X410(FG) using Tapatalk
Better to die on your feet than to live on your knees.
I dont need a speedo just a tach.Time slips tell me the rest.But my 1200S is mainly a drag bike.Only reason I have plates and ins on it is to be half ass legal to run it out the road to tune the carb.
DramaLlama's Avatar
DramaLlama DramaLlama is offline
DramaLlama is an unknown quantity at this point
I wish I would've taken mine to the track to see how it runs before the bike started having a bunch of issues. I'm thinking of doing some upgrades for the winter since I'm having battery and starter issues and need to figure that out anyway. Need to do some cam research.
I also run the Super E, thunderheader and I believe in the early 2000s the cylinders were bored .001 which probably just means it was rebuilt?
Originally Posted by Edster View Post
I killed my speedo that way(I suppose). It would read either 30mph under or the needle would just bounce. I replaced it with a Dakota Digital MCL3200. I had to solder a bunch of wire together. Although the line to the Speedo sensor was plug and play. http://uploads.tapatalk-cdn.com/201...b414641cb0.jpg
How do you like the dakota? I was planning on doing a build with this bike a while ago, so started buying some nice stuff. Grimeca brake and clutch, motogadget guage, custom braided lines, etc. etc.. Then I decided since the engine hit 50k miles that it was time to sell it. But no one wanted it for what I was asking so now I'm back to possibly building it up a bit.
It leaks oil from multiple places, so likely will have to tear down the motor and then I might as well do some upgrades. Just need to figure out what I can afford. Unfortunately not many great shops in Vegas that can reliably do this kind of work. Not that I know of anyway.
1998 1200S
Edster's Avatar
I like it quite a bit. It is an all in one deal. Rach, speedo, two trip meters, a clock and other functions that I haven't used. 350 USD vs the 400 for a stock speedo. The stock tach was on it's way out too and would have been another 300 USD or so.
Old 13th October 2019
84cj 84cj is offline
Other Motorcycle Model: Yamaha Virago 1100
Other Motorcycle Year: 1995
84cj is an unknown quantity at this point
Phew! Finally finished all 189 pages.
Picked up a 1999 1200S about 3 weeks ago. 11,000 miles, two seats, soft saddle bags (old), forward controls, different handlebars, small windshield, S&S carb-air cleaner-intake, and V&H straightshots.
Had issues with it idling. Took the carb off, full of crud. So I pulled the tank also. Still would only idle with the enrichner pulled up about 1/4 of the way. Pulled the carb again and noted the intermediate and main jet sizes. Also found the intake gaskets were leaking, not installed properly like a few other things I've come across. Carb was jetted for an 883. Ordered up a larger intermediate and a few mains, idles great now.
It's my first Harley. First bike was a 2008 Suzuki S40, than a 1995 Virago 1100.
sportsterdoc's Avatar
Welcome from southern Nevada.
My 2002, riding from close to sea level to 8,000 feet elevation,
liked a 45 (0.45 mm) pilot jet, N65C needle and a ~200 main (2.0 mm).
If not going to run for a while, since the Sport has no bowl drain, you may want to shut off fuel and let it idle until it stops.
