Last Post: hbsporty
0 Xl???
Last Post: SLW210
0 AHDRA Orlando speed world??
Last Post: painterdude923
Last Post: SLW210
0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
0 Your never too old
0 Tuners
Last Post: Sirrom1
0 Morning default to odometer
Last Post: Eric Von Zipper
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
  #101
Old 5th July 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Penetrating oil and anti-sieze apparently doesn't work that well.
Corrosion X does. Everyone should have a can sitting around...
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Old 6th July 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Thanks for the tip. I'll have to check it out.
Old 10th July 2019
Dazed & Confused
I just did another clutch adjust after installing a ClutchLite release ramp.
The FSM procedure does suck. It is difficult to feel what's going on turning the screw if you haven't done this a lot and even then it's vague at best.
What is much easier is to grab the release arm where the cable attaches and check for movement there. Clearance (or lack of clearance) is obvious there as you adjust the screw. Check for release arm movement, same direction as the cable operating the release. You can easily feel the clearance (free play) change at the arm as you adjust the screw vs the vague feel you get at the screw.
Old 10th July 2019
Toejam503's Avatar
The first time I adjusted my clutch, I had burned my fingertips at work a few days before. That had made it easier to "feel" the screw touch. Now when I adjusted it, I had to check it 2-3 times and remembered it from memory. {Caution: Do NOT intentionally burn your fingers to make them more sensitive, it's just plain Stupid!} Live and Learn.
Old 28th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
I just did a readjust on my new E1. I use the method Tomcat mentions as I like to get it as tight as possible and back off no more than a 1/4 turn. Reason being is I also leave a lot more than 1/16" of play in the cable. More like 3/16". This makes for a short throw so it needs to start engaging pretty quickly.
Not for everyone and requires adjusting a little more frequently as everything needs to be just so.
Old 28th July 2019
rocketmangb's Avatar
The screw is not that tricky "IF" you have adjusted solid lifters
Counter clockwise until you just feel it "Kiss" then clockwise 1/4-3/8 turn
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
