0 New oil tank
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
0 Your never too old
Last Post: Sasnak75
0 Stock 02 883 FS
Last Post: Jvb13
0 Repainted my bike
0 Magneto points & condenser
Last Post: Nitro57xl
0 The Sport(ster)ing Life
0 Xl???
0 Now I did it. Feel my pain
0 Hi everyone
0 Hello from LA area
Last Post: webman94
0 Morning default to odometer
0 Tuners
Last Post: Zoo
0 DUAUL DISK SPRINGER? Experts Help
Last Post: Samedward
0 Ulysses Oil Fittings?
0 AHDRA Orlando speed world??
Last Post: painterdude923
0 Sportsters in movies and TV
Last Post: SLW210
Old 24th June 2007
hdmc_ru2's Avatar
hdmc_ru2 hdmc_ru2 is offline
hdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura abouthdmc_ru2 has a spectacular aura about
Default Adjusting Screw
How far are you all finding that you need to turn the adjusting screw counter-clockwise until you feel resistance?
I found that I only had to turn it about 3/4 of a turn before I felt the resistance. I then backed it off a 1/4 turn clockwise from there.
Seemed pretty minimal.
Great post Chris, thanks for the pics.
Joe and Son
Old 25th June 2007
spby52 spby52 is offline
Sportster/Buell Model: buell mutant
spby52 is an unknown quantity at this point
nice demo...sure is helpful....I have problems with o-rings down south in the heat...I stick them in a cup of ice..shrinks them up a little helps them fit better....
Old 26th June 2007
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
Seems that was about how far I got also till I felt some decent resistance, again it's a feel thing you'll have to play with a little till you get it right.
Once you get it though you're home free on the next adjustment.
Glad this helped someone, Chris
My Other Toy Goes Mach 25
Old 7th July 2007
ambulldogg's Avatar
ambulldogg ambulldogg is offline
Sportster/Buell Model #2: 883-1200
Sportster/Buell Year #2: 99'
ambulldogg has disabled reputation
cjburr ur the MAN!!! thanks alot for the full detail! i have a 99 and it was the same thing! nobody responded to my posts so i tried this out and it worked like a charm!! mad props bud!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.myspace.com/gadget2278
AIM--loudpipes74
Do What You Can Do When You Can Do It!
Old 19th November 2007
shedds's Avatar
shedds shedds is offline
shedds has disabled reputation
i have the same problem when the bike is put into first gear after sitting overnight or just for awhile sometimes if i hold clutch in for awhile it goes right in no clunk or grind but to my knowledge i never had it adjusted and now the bike has 6200 miles on it (what do you think ? could this be the problem)
Don Burton's Avatar
These are constant mesh transmissions so the gears are never making grinding noises while the dogs might be when attempting to shift.
Wet clutches like ours will always have a tendency to stick a little when left overnight or longer, which can create conditions for a noiser engagement when the dogs for first gear are first engaged after the bike is started up. On my old Triumphs and Norton I used to kick through in neutral with the clutch lever pulled in in order to free up the clutch before starting. On my Sporty I merely put the gearbox in first before starting and back the bike out of my garage with the clutch lever pulled in. That serves to break the clutch loose.
Adding more fluid than is required can make the clutch stick more. Adding 28 ounces after draining brings my primary level right up to where the manual recommends. Adding more would not be helpful.
A loose primary chain can increase the clunk when shifting
Minor differences in clutch adjustment can cause things to act differently.
Old 20th November 2007
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Shu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant future
While it is important to keep the clutch and primary chain within adjustment tolerances, that alone will not stop it from clunking into gear sometimes. Don explained it very well. What I do to free up the clutches before putting into gear is pull in the clutch and then rev the engine a little (blip the throttle), then slip it into gear....and it will jsut slip into gear
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 29th March 2008
hooptygoo's Avatar
hooptygoo hooptygoo is offline
Sportster/Buell Model: XL1200CSDSPC
Sportster/Buell Model #2: Ducati HyperMoto 1100 S
Other Motorcycle Model: GPz 750 - sold to Chica
Other Motorcycle Year: 1982
hooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to allhooptygoo is a name known to all
Should the clutch lever be pulled in or out when making the adjustment?
Thanks,
Jon
XL 1200 Custom Super Duper Sport Poser Cruiser (sold)
2009 Ducati Hypermotard S ("S" is for Superhero)
Old 29th March 2008
hooptygoo's Avatar
Or, does it even matter?
Old 5th April 2008
doxbike doxbike is offline
Sportster/Buell Model: FatBob
Sportster/Buell Model #2: all gone 1200R
Other Motorcycle Model: Honda ST1300;Goldwing1500
Other Motorcycle Year: 0407
doxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of light
Cool
Started my 10 K service today, so I figured I might as well check the clutch adjustment after all the horror stories on the XLF lately.
When turning the adjusting screw counter-clockwise, I noticed the whole assembly lifted as resistance was being felt. I re-checked it several times, and it seems the assembly lift will top out just as resistance is being dialed in. It doesn't go any higher, even if you continue to tighten it. So, I think this will serve as a double check for your "feel" to be sure you don't over-tighten the clutch. I then backed the screw off 1/4 turn which resulted in a final position 1/8 turn counterclockwise from where it was when I started.
Maybe it's all in my head, but the butt-dyno says it's faster-who knows, maybe there was a slight slip before? Only time will tell.
The Quad-ring was twisted in 2 spots (by the dealer) I moved the twisted areas up to the 12-2 o'clock position, so hopefully it won't leak-hasn't yet.
All HD's gone now-Riding a Triumph Tiger 800xc and a Goldwing-time's they are a'changin'
