0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
Last Post: owlsplace
0 Your never too old
0 Tuners
Last Post: Sirrom1
0 Morning default to odometer
Last Post: Eric Von Zipper
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
0 E85
0 Sportster drag bike
Last Post: Zip1
0 Cosmo's ECM Relocation Mod
Old 17th March 2007
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
Originally Posted by TheForce View Post
You are a lifesaver. I was reading my service manual and just wasn't getting it. Your pics saved the day. I will be changing my clutch cable tomorrow.
You will need a new seal where the clutch cable goes into the primary. There is no need to remove the primary cover just to change the cable.
You just need to follow the post till the ramp is removed from the cable, and then unscrew the lower clutch cable from the primary cover.
Glad it helped you, Chris
My Other Toy Goes Mach 25
Old 17th March 2007
cootertwo's Avatar
cootertwo cootertwo is offline
Sportster/Buell Model: 06 883/1200 Sportster XLC
Sportster/Buell Year: 06
Sportster/Buell Model #2: 1200 Roadster
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Triumph Rocket lll
cootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to allcootertwo is a name known to all
Chris, thanks a bunch, I just got a new diaphragm spring from Energy One (25% stronger) and was searching for "how 2"s Why is it necessary to replace the retaining ring? Is is destroyed when you remove it?
One Day At A Time
Old 17th March 2007
cjburr's Avatar
I'm not sure, it came out very easily with no damage, I used my brass O-Ring removal tool. The manual says to replace it, just as they say to replace all snap rings after they are used.
Cheap insurance I guess, or the MoCo going for every penny.
Use your own discretion here.
How long did it take Energy One to get you your parts ??
Old 17th March 2007
cootertwo's Avatar
Chris, when I ordered my new spring, I picked the cheapest shipping, I thought. It was $20.00 shipping, for a $16.00 spring! Turns out, it was UPS second day. Got it two days after I ordered it! I'm afraid I might have went overboard with the 25% stronger, but we'll see. I don't want to be poping clutch cables on a regular basis. I think I will have to order the compressor tool. Thought maybe I'd try to make something, as I'll probably only use it once or twice, at the most. I wonder if those threads on the adjuster are standard, or metric?
Old 17th March 2007
Jimbos883's Avatar
Jimbos883 Jimbos883 is offline
Sportster/Buell Model: 883/1212 XL Custom
Sportster/Buell Model #2: XLCH STROKER
Sportster/Buell Year #2: 1959
Jimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to behold
Chris in your travels have you ever run across what the actual spring force is? I have been unable to find any specifics on the stock springs and Energy One only makes claims of 15% and 25% greater spring pressure, no real spring force numbers.
Sure would like to know what the new 883's have and the new 1200's have and also what exactly is Energy One supplying.
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
Old 17th March 2007
cjburr's Avatar
A friend at work found somewhere on the web that the stock 1200 Sportster clutch was designed for 80 to 85 HP.
Most things like this are at least a little overengineered from the factory.
Old 17th March 2007
Gone Gone is offline
An excellent post
Old 17th March 2007
Jimbos883's Avatar
If that is true then any of the new 1200's with any new cams are going to be "right there". It would seem to me that if you plan on doing anything to the new Sportster motors to make horsepower you should also include a clutch upgrade.
I was going to go with the "stock 1200" spring but now it seems that it makes much more sense to go the Energy One route. It would really be helpful if we had some actual numbers to compare. I plan on speaking with Energy One next week. If I find out any hard numbers I'll report back.
I'm waiting to see how your upgrade turns out on the dyno. Please report back ASAP we're all waiting to hear.
Old 18th March 2007
cjburr's Avatar
No joy for me on getting my clutch pack today
Perhaps Monday
Old 18th March 2007
Don Burton's Avatar
Good info on where to buy the tool as well as info on springs.
