0 mainshaft rollers size
Last Post: thefrenchowl
0 Roadster - No Key Start
0 XLCR replica in progress
0 What engine oil do you use?
Last Post: SLW210
0 81 parts
Last Post: Andy Hog
0 my sunday driver...
0 Halloween 1250 Conversion
0 Top end rattle at 3000 rpm
0 Northern Canada late 1950’s
0 Cam question
Last Post: T. Clark
0 tappet/blocks fitment by year
0 MS rollers way too tight
0 Secondery Vin tag
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
  #311
Old 18th August 2015
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Originally Posted by Fatman View Post
Just read the whole of this thread - fantastic reference. I have just had a failure of somesort on an XL 1200S.
This thread is specifically about the clutches on rubbermounts, and doesn't necessarilly translate to your solid mount.
Folkie
South East England Riders
Old 3rd September 2015
rhariz21 rhariz21 is offline
rhariz21 is an unknown quantity at this point
just did mine. 05 1200c. 13000 miles. lost all the rivets and killed my clutch
went with energy one and love it!
Old 16th December 2015
outlawreb's Avatar
outlawreb outlawreb is offline
Sportster/Buell Model: 1200L
outlawreb has disabled reputation
my '06 is needing the spring plate replaced it will be the second one this time im putting in a whole new set and throwing it away
OUTLAWREB
Old 5th November 2016
Mike 1200R Mike 1200R is offline
Mike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to allMike 1200R is a name known to all
What happened to all the photos?
Folkie's Avatar
Brass Nut
Photobucket is down for maintenance.
