0 Speed
0 1200 conversion
0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
Last Post: Skeezix
0 5 gal tank
Last Post: Magneto Sportster
0 opinion time (bike broke again)
Last Post: Skeezix
0 testing wiring harness connections
0 2011 1200C tuner?
Last Post: tussuck
0 Timing
Last Post: ezmerf
Old 30th May 2009
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Originally Posted by dave76 View Post
Cool thats what I wanna hear. Question? whats the revs at 70MPH??? and whats the off the line like???
The revs at 70 on both are around 3300 I can not tell on the ironhead as it's in kph.
And off the line in first it's never any trouble just rev to around 1500 rpm and feed out the clutch, never stalled it yet?
When going slow in 4th in town I can get right down to 1150rpm which is about 31 mph. If I use 3rd it's to much noise and then the police will pull you.
Old 30th May 2009
dave76's Avatar
dave76 dave76 is offline
Senior Master Bike Builder
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
Thanks for the input man.
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
Old 14th June 2009
oldmetal oldmetal is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 85
oldmetal is an unknown quantity at this point
enginetorque,
transmission mainshaft roller bearing is lubricated by gravity from a gutter located on the roof of the trans case (right crankcase half). This gutter fills by splash and drains oil down through a hole to the outside of the rollers between the bearing and the oil seal. Check to see that this hole is clear and that the seal or the bearing outer race (roller cup) is not obstructing it.
Old 27th June 2009
NC_REDNECK_1981's Avatar
NC_REDNECK_1981 NC_REDNECK_1981 is offline
Sportster/Buell Year: 1988
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1984
NC_REDNECK_1981 is an unknown quantity at this point
would it be possible to take a tranny out of an 84 ih and bolt it into an 88 1200 ? i would like to get a little better gearing and cant afford a new tranny or have mine rebuilt. i have a tranny out of my 84
;)1988 1200
Old 3rd July 2009
dave76's Avatar
As long as it's a late 84 with the alternator behind the clutch, then hell yes it'll bolt right in. You can also just buy the late 84-early 86 clutch gear and countershaft gear.
They have it cheap as hell on ebay right now, just need the 1958-1986 27T countershaft gear.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 7th July 2009
Gone Gone is offline
Banned
Gone is an unknown quantity at this point
This may be the wrong forum, but y'all really seem to know your stuff. Has anyone ever tried/ is it possible to run a four-speed tranny in an '03 sporty. Also, is it possible to get a kicked transmission to turn over an Evo engine?
Old 7th July 2009
ted's Avatar
ted ted is offline
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
Cool
no x 2.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
Old 13th July 2009
dave76's Avatar
No, and why would ya want to?? As far as kicking an Evo, I don't see why not, same compression as the Ironhead, but their is no way to install a kicker in any Evo, or any 80-85 Ironhead for that matter.
Old 2nd October 2009
dave76's Avatar
Got some new pics of my tranny.
Stock trap door and close ratio gear set still installed
Zippers billet trap door
Here is what my stator magnets looked like after I pulled her appart
The new V-Twin sealed magnet clutch shell for L84-90 Sportsters
Old 17th August 2010
misterMagoo misterMagoo is offline
Sportster/Buell Model: Sportster 883 XLH
Sportster/Buell Year: 1989
misterMagoo is an unknown quantity at this point
Lets say you have a bike that was converted to belt drive. How would you figure the correct ratios needed then? Are the teeth count the same on the secondary drive sprockets?
Also, are these the only parts you need to replace in the transmission?:
Clutch Gear: 37448-84A
Countershaft Drive Gear:35695-58
