0 Newbie
Last Post: randy3934
Last Post: wongjohnson
0 OEM Headlight Bucket?
0 Chris Farley Bike
0 Mid Control?!
Last Post: MikeBel
Last Post: leon bee
0 MS rollers way too tight
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Grateful Dead Timing Cover Source?
0 Halloween 1250 Conversion
0 Better Brakes
0 Northern Canada late 1950’s
0 Oil leaks
0 oil bag
4 1995 S2 buell
Last Post: J!nx
0 Spacer swingarm bearing
Last Post: eddie XLX
0 81 parts
Last Post: Andy Hog
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: Desertfox
0 XLCR replica in progress
Last Post: rg500
Last Post: XL1275
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
  #61
Old 23rd February 2016
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
I am about ready to rebuild my tranny and was wondering if you need the bearing install tool to put the bearing in the right case for the mainshaft?
It's Hammer time
Old 8th April 2016
Jrivera1392 Jrivera1392 is offline
Sportster/Buell Model: 883 standard
Sportster/Buell Year: 1989
Jrivera1392 is an unknown quantity at this point
Does anybody have any info on the procedure for replacing the shifter shaft on my 89 4 speed trans. The splines on mine are stripped, does the trans need to come out in order to do this?
Old 8th April 2016
juzyHD's Avatar
juzyHD juzyHD is offline
Master Bike Builder
Sportster/Buell Year: 1986
Yes the trans must go out. You should get a repair manual, it's the easiest way to do things..
Old 25th May 2016
lelo lelo is offline
Sportster/Buell Year: 1987
lelo is an unknown quantity at this point
question regarding trans sprocket. Im in the process of converting my 87 sportster to a wide gear ratio as mentioned in post #1. I bought a 23 tooth trans sprocket and was gonna leave the rear 48 tooth. Problem is the chain is too small, and i noted if i were able to install the 23 tooth sprocket i would have clearance issues with the chain. could i run the stock 21 tooth trans sprocket with the 48 rear, just temp will i get a new chain or a different size sprockets?
Old 25th May 2016
benton benton is offline
Sportster/Buell Model: Sportster Delux 883/1200
benton has disabled reputation
To use a 23 front sprocket you'll need to deemed some material away, but a 22 will fit OK. I found a 22/48 ratio to work best for me, but I don't do a lot of freeway miles. The 22/47 combo was a bit too high for me.
Old 25th May 2016
Best tip is to hang some vice grips off the shaft when reinstalling to keep it oriented.
Old 17th August 2016
WI_duker's Avatar
I see your zippers double row bearing is made in China as well.
Old 15th April 2017
Saddletramp Saddletramp is offline
Sportster/Buell Model: Sportster Chopper
Sportster/Buell Year: 1990
Saddletramp is an unknown quantity at this point
Awesome info on the original post. I came across this a year ago as I was rebuilding the motor while chopping my 90 sportster. Got it all together now as I also used all the info posted on here. There is now a significant difference in top end speeds.
Old 25th February 2018
question regarding the mainshaft 2nd gear and countershaft 3rd gear. are there any differences between them. i know both are 23 tooth but one seems thicker and the spacing between the dogs are clearly different. which one is which?
1987 sportster
