0 .551 Cams in an EFI 1200
0 1993 XLH883 Ignition switch Wiring
0 Multiple timing marks?
0 Handlebars
0 Riding in the rain
Last Post: seajay
0 Removing countershaft from access cover
Last Post: Russ
0 Anti reversion “muffler”
Last Post: JaKaL
Last Post: a-sad-anorak
0 question about new trans door
0 Where were the IronHead sportsters Made.
0 BMW reverse trike build
vlmuke, wazza (48), Grizzwold (44), roaldtm (39), redtacoma31 (34)
  #151
Old 14th April 2019
PetesPonies PetesPonies is offline
Sportster/Buell Year: '59
Sportster/Buell Model #2: 2004 XL1200R
Other Motorcycle Model: 2006 XL1299R
PetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant future
Originally Posted by Turbo Sporty 48 View Post
Thanks a bunch.
Used your measurements to finally get to fix my '08 Roadster ECU relocate problem.
Ordered a Battery Tender BTL12A270CW, numbers, tech changes so fast.
Last time used the turbo toasted the ECU cover on the '10 48, need to relocate the ECU away from the rear exhaust port, back of the head.
You guys helped me solve 2 problems, yippee.
Very cool. I'm still building this Roadster that I want to move the box. I am working on it here and there. Just getting ready to paint the wheels. I haven't need to move the box yet, but it's on my mind. What battery did you end up buying?? and did you need to do anything to the wiring harness to the box?
Pete's Ponies Mustang RUSToration & Performance
Old 14th April 2019
Sportster/Buell Year #2: 2008
Default First things First
Ordered a Battery Tender BTL12A270CW.
Actually, want to order new fenders. The rear is rusted and has the ecu in the fender. Cannot use the comfy Sundowner seat already owned. First things first.
The wiring manipulations are yet to come. Will post about it when done. But it has been done and pictured earlier in the thread.
Old 14th April 2019
OK I was confused. I saw Battery Tender and thought it was a charger/maintenance device, not a battery
Old 14th April 2019
I just looked that battery up . . ouch !!!
Old 14th April 2019
Lithium can last a very long time.
Did you check out that batteries features?
Not trying to sway you, being thrifty, this purchase took a long time to justify.
Old 14th April 2019
No didn't look hard at it. I've read a little, know there are benefits. Seems the IRON is the style to get, not an ION.
Old 23rd May 2019
Gosh am I slow.
Sent back the Battery Tender battery, caution if you buy by Amazon, manufacturer might not want to support, not worth the hassle, just sent it back when there was a problem.
Bought an EarthX ETX24C from the manufacturer. Starts right up.
Put on the Sundowner seat that was given with the bike when I bought it about 5 years ago.
ECU is above the battery, snuggled in with foam sent with the battery.
Last edited by Turbo Sporty 48; 23rd May 2019 at 17:00.. Reason: Corrected battery item number
Old 23rd May 2019
rejeanprimeau's Avatar
Just strap the battery, lithium don't like insulation around them.
Old 23rd May 2019
Gosh am I slow.
Bought an EarthX EXT24C from the manufacturer. Starts right up.
ETX24C . . you got the T and X backwards , if anyone is looking for one
Old 23rd May 2019
Default Thanks
I corrected the mistake in the earlier post.
Thanks for pointing it out
