0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
Last Post: Skeezix
0 5 gal tank
0 Speed
0 1200 conversion
Last Post: Magneto Sportster
0 opinion time (bike broke again)
Last Post: Skeezix
Last Post: r100steve
0 testing wiring harness connections
0 2011 1200C tuner?
Last Post: tussuck
0 Timing
Last Post: ezmerf
0 Mild 1250 build thoughts?
View Poll Results: which brand slip on
Screamin eagle 248 30.21%
Cycle shack 172 20.95%
Rush 91 11.08%
Vance and Hines 174 21.19%
Hard Krome 3 0.37%
other 131 15.96%
Akrapovič 2 0.24%
Voters: 821. You may not vote on this poll
Old 20th August 2007
rdgzoe's Avatar
rdgzoe rdgzoe is offline
Sportster/Buell Model: 883/1200 Sportster Low
Other Motorcycle Model: DYNA Street Bob
Other Motorcycle Year: 2007
rdgzoe is on a distinguished roadrdgzoe is on a distinguished roadrdgzoe is on a distinguished roadrdgzoe is on a distinguished roadrdgzoe is on a distinguished road
Low price and after rejetting the dealer said as far as power is concerned it would get 80% there.
big blue big blue is offline
Sportster/Buell Model: XL883L
Other Motorcycle Model: CB 500
Other Motorcycle Year: 1973
big blue is an unknown quantity at this point
Leo at Frantic Custom Cycles has some slip-on drag pipes that are great for the price. Loud but great. It takes a light hand to keep them quiet. If I don't care, I set off alarms and have cops following me everywhere. And that is with the baffles in!!!
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
I've got SE SPs. I wanted something louder than stock but not as loud as, say, V&H or Cycle Shacks. The Street Performance mufflers are just right.
Folkie
South East England Riders
Old 21st August 2007
gomorley's Avatar
gomorley gomorley is offline
Sportster/Buell Model: 1200Custom
gomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant futuregomorley has a brilliant future
I put V&H straightshot se slipons on and think they're great, sound and performance is tops there definitely not quiet!!!
I'm a bad, bad TROLL....
kavika420's Avatar
kavika420 kavika420 is offline
kavika420 is an unknown quantity at this point
Default StraightShots HS Slipons
Going to attempt to install V & H StraightShots HS SLipons on my 07' 1200L. Could you guys discuss some tips/suggestions on the install? Very much a novice at this but I'm pretty determined. Thanks.
langner91's Avatar
langner91 langner91 is offline
Other Motorcycle Model: FLHTC - Finally!
Other Motorcycle Year: 2008
langner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the rough
Here are some random thoughts / tips.
1. Use PLENTY of WD-40 to get the old ones off. They might take some time, so be prepared and patient. Some slip right off, some take a little effort. Yours should be OK since the bike is so new.
2. Use PLENTY of Windex on the new ones AND the Heat Shields when you are done and before you start the motor. It will prevent your WD-40 laden finger prints from becoming permanently burned into your chrome.
3. Spend the $3.00 on new exhaust gaskets. Have them on hand at the beginning of the install. I ended up stopping to run to the Stealer for some.
4. If your new slip-ons do not come with new mounting bolts, go buy some new ones at the hardware store. They get really cruddy and you might strip the heads getting them off.
5. Don't buy new clamps. Re-use the old ones. I don't know why they say you can't re-use the old ones.
6. Be careful tightening the clamps on the heat shields. I broke one and had to run to the hardware store for another clamp. Just a pain in the a$$, not a big deal.
Good luck. It really isn't hard.
BTW, I did mine on an '06 so there were no O2 sensors. Be careful you don't move things too much to break / stress / bugger up the O2 sensors.
Brad Brad is offline
Sportster/Buell Year: None
MCM Chrome 2" Slip on Drag Pipes, from Frantic Custom Cycles. Great sound, great price, and Leo is a supporting vendor. Also, because they have removable baffles, I get to play around with the sound.
Here's a link to Frantic Custom Cycles.
Here's a sound clip before I got rid of the fiberglass packing around the baffles.
mister's Avatar
mister mister is offline
mister has disabled reputation
I bought my 1200R new with stage 1 a/c kit and Screamin Eagle II pipes. I wouldn't change it....Love the sound.
2005 Roadster 1200
>Stage 1 Screaming Eagle A/C kit
>Screamin Eagle II mufflers
>4.5 gallon tank
>Lots of extra goodies
rick szymanski's Avatar
rick szymanski rick szymanski is offline
rick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to beholdrick szymanski is a splendid one to behold
khrome werks....it really works!
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
Cycleshack. $45 on ebay and a higher top end.
It seemed to me that different slipons really weren't much different. More restrictive versus less restrictive. The cycleshacks reduced restriction and I found a used pair listed on ebay for cheap.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
