Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sport-Glide / Sportster Motorcycle Touring
Last Post: burely
0 Seized 1200SPORT Fork Cap
0 Intake manifold
0 Screamin Eagle Wiring
Last Post: AntonieR
3 Shaky Dave Recovery
Last Post: Hornsmith
0 FS Front brake line from '03 45121-96A*
Last Post: slamtry
0 "S" model specific Q&A
0 900 heads contd..
Last Post: simonster123
0 Tank Paint Ideas
Last Post: MotorPete
0 Fuel tank urns
Last Post: ezmerf
0 wrong brake fluid
0 Trans corner fix
0 Anyone know where I can get one of these mini fairings?
0 98 s10
Last Post: ezmerf
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Oil hungry Iron Heads
0 Getting Hammered
Last Post: Bryan1976
0 exhaust gaskets
0 New member from snowy Colorado
0 new member
cobra0478 (76), Han (63), priell3 (59), Byrdman (55), jsta (53), YaeDio (52), chad.hart17 (47), doc (46), jfunk (46), lenainrouge (45), JohnDao (41), Razer883 (34), Slapchop68 (26)
  #181
Old 21st November 2017
SonWon SonWon is offline
Sportster/Buell Model: Superlow 1200T
Sportster/Buell Year: 2016
SonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond reputeSonWon has a reputation beyond repute
Thank you! I will likely be a few pounds over max vehicle weight so I knew there could be a problem. Lighter front ends I am use to however not in a road bike. Anyway I did have a concern and will test it carefully. The tire cupping could be due to a mechanical problem. I would go over the whole bike starting with the front end and check the motor mounts if they are bad or not torqued correctly...
Sorry John for making you post those again I thought you had a link to share and now I don't read that into your link. Must have been a brain hiccup.
Old 18th August 2019
Tonyb65's Avatar
Tonyb65 Tonyb65 is offline
Sportster/Buell Model: XL 883 DLX Sportster
Tonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to all
1995 XLH 883 DLX
Vance and hines original straight shot exhaust
Two up seat with after market leather/PVC slant saddlebags
Hydra glide Front End with full fat boy fender 7inch LED head light and 4 inch passing lights Shinko HD 777 touring 130/90b 16 tire with laced front and rear wheels and a 21 inch National cycle ridged mount windshield
next upgrade 4.2 gallon flatside tanks off of a 94 FLSTF Fat boy
still working on the tank project going to lower the tank so it will ride parallel with air cleaner
Last edited by Tonyb65; 23rd September 2019 at 14:44.. Reason: correct type o add photo
