Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Riding Tips & Safety Advice
Riding Tips & Safety Advice Got a question about your riding technique or safety issues?
6 ironhead turn signals
10 DEEP DIVER's JOKE
0 KR style bolt on hard tail for 78 XLCH
Last Post: 45Brit
Last Post: webman94
0 2015 883 with S&S 1200 conversion kit
Last Post: sportyone
Last Post: rocketnorton
0 93 883 Key switch and lighting
Last Post: bklyngeezer
0 Riding music
Last Post: XL1275
0 Significant exhaust pop at idle.
Last Post: firevf06
0 Cobra NH slipons
Last Post: Skeezix
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
0 The salty debate thread.
0 Hello New in the Forum
Old 9th January 2006
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Two things about the green that make it more difficult and dangerous than the yellow. First, it requires trail braking. You're spending a lot of time in the turn and to do it fast you're forced to combine turning and braking on the entry. The other thing is the exit. You haven't left yourself any room for error. Go through it too hot and you'll run out of road on the exit and be in trouble.
With the yellow, you've done your braking largely before your turn-in, so you're not forced to combine braking and turning. But the big thing is you've left yourself room at the exit. If you run out of road, or if something unexpected shows up, you've got a safety margin. All you have to do is roll out of the throttle.
Confused89's Avatar
Confused89 Confused89 is offline
Sportster/Buell Model: Had a 1200 XL
Other Motorcycle Model: FLHTP Electra Glide
Other Motorcycle Year: 2011
Confused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud ofConfused89 has much to be proud of
I just follow those yellow warning signs before a corner. This just may be inexperience talking but I have found out that you can enter a corner 10mph over those signs if they have a speed of 20mph or more posted. If they have 20mph or less it is a wise idea to follow them. This is just something that I have noticed. I have never had a problem so far.
denise1955's Avatar
denise1955 denise1955 is offline
Sportster/Buell Model: 883C
denise1955 is on a distinguished roaddenise1955 is on a distinguished road
Default Great post
Thanks for the educational post Steve. As a new rider, I really appreciate any article like this .... I'm going to print it and bring copies to my next Women on Wheels meeting. It's something both experienced and newbies should read.
Denise
'05 883C
johnnysquire's Avatar
johnnysquire johnnysquire is offline
Sportster/Buell Model: 883 XL
johnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nicejohnnysquire is just really nice
I use the "posted+20" rule in my cage (a tuned BMW 3-series) - on the bike I worry too much about gravel/salt/potholes to go that fast. Does your "posted+10" leave any room for in-flight adjustment?
ABSOLUTELY!
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
I too have read that article before, but it's worth another read. I get what everyone is saying about the apex thing, but it made sense to me - I intereperted the "tightest part" as the part where you in closest to the inside of the turn, but same difference either way.
I generally use a slightly different rule for the yellow speed signs...I find that you can almost double the posted speed and still leave room for adjustment. However, that only works when you take a good line. If your line is crap with a really early entrance point, then you could end up in the weeds going 10mph under. I use those signs to give me a baseline to judge from - then I set myself up and make my own adjustments as neccesary.
In any event, it's a good thing I read this article - on one of my last rides of the season, I tried following my buddy on a Buell through a turn and scared myself to death...I was taking an ideal line, but I went in WAY too fast and ended up pushing way wide anyways, crossing over to the outside of the oncomming lane with the exhaust scraping the whole way. I will give myself some credit though - I didn't get hard on the brake or try to stand the thing up - I kept on leaning into the turn...I would have been down for sure otherwise.
I'll be taking the late entrance line from now on...
Me too, but I have to know the curve so that I know there's nothing on the otherside of a blind curve or torn up road or gravel etc.
denise1955's Avatar
I'm new to riding (this was my first season) and I don't know a lot of the lingo. What does "late entrance line" into a curve mean?
check out the graphic on page 2 of the thread.
It's the yellow line.
Late entrance line, means you drive deeper into the turn before actually leaning/initiating the turn.
K
DM-SC's Avatar
DM-SC DM-SC is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Heritage Classic
DM-SC is an unknown quantity at this point
Like I said...it depends upon how fast you're going. In my case...that's so slow it really doesn't matter!
Some minds are like concrete..thoroughly mixed up and permanently set!
2004 Heritage Classic - Ness Big Sucker, V&H Longshots, PCIIIUSB
Former Sporty Pilot...Now riding a "Road Sofa"
