0 Hi everyone
0 Repainted my bike
0 Hello from LA area
Last Post: webman94
0 Morning default to odometer
0 The Sport(ster)ing Life
0 Xl???
Last Post: 1200CustomHD
Last Post: rocketnorton
0 Your never too old
Last Post: ss396
0 Tuners
Last Post: Zoo
0 Now I did it. Feel my pain
0 Magneto points & condenser
0 DUAUL DISK SPRINGER? Experts Help
Last Post: Samedward
0 Ulysses Oil Fittings?
0 AHDRA Orlando speed world??
Last Post: painterdude923
0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
Last Post: Sirrom1
Last Post: leon bee
Old 18th April 2017
rocketmangb's Avatar
Default Clutchlite ramps with pictures
Left is X Soft right is XX Soft
Heres it is assembled with the XX Soft inner and MoCo outer and the 13/32" balls which are .03125 oversize, Hope this shit works with a 20% Barnett spring ,Barnett cable,and my Alto Carbonite clutch !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 18th April 2017
You can measure the rotation of the stock 'Ball & Ramp' and the width they achieve with that rotation...
Then, rotate the new combination the same amount (degrees rotation) and measure the width that combination achieves...
As long as the 'Ball & Ramp' separate to an equal distance as before, the clutch plates should be properly released... Then it's just a matter of setting the right starting point (just when you feel tension - 1/4 turn)...
http://sportsterpedia.com/doku.php/t...sign_operation
Be sure to update us on how it works out...
IXL 2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
An XLForum collection of technical info & advice
Old 18th April 2017
Total experiment on my part !
Old 15th May 2017
Hippysmack's Avatar
What was the outcome?
Old 15th May 2017
rejeanprimeau's Avatar
Mine work fine, I adjust 1/4 and slightly more for the the locking plate falling in.
Old 15th May 2017
No time to install it yet !
Old 7th June 2017
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
Will they fit 2003 XL1200?
2003 XL 88"
Old 7th June 2017
I believe so.
Old 7th June 2017
I believe so.
Thanks will fit one , felt clutch pull on new sporty at dealer other day, was feather light
Old 8th June 2017
The OEM inner ramp for a Sportster appears to be the same back to the 4 speed EVO.
25453-87A
See no reason it wont fit any 5 speed
