0 AGM battery for 76' XLH
Last Post: JonesL
0 S&S Super E Carb
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: Nitro57xl
0 so it's officially ended
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
  #171
Old 15th March 2018
Originally Posted by THIRDEYE View Post
Thanks for that suggestion..With both standard bulbs in sockets, they all work normally..
That sounds like the equalizer you bought is not working - or you have it connected wrong...
You didn't answer my questions:
Did you contact your vendor for the Badland module?
Do you have a TSM or TSSM?
2 Relax
FREE XLForum Organized Tech Info - Check Out The Sportsterpedia
