Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Last Post: Bow only
0 Too HOT to ride?
3 Shaky Dave Recovery
Last Post: Serious Blac
0 Idle / transfer ports Q
Last Post: Billy1200
Last Post: c1skout
Last Post: CMCSSeabee
0 Glyptal?
0 Photo bucket
Last Post: duffy
0 TC88A update ?
Last Post: savagegarden
0 Long intake
0 External breathing systems
0 no spark
Last Post: harley in fl
0 Options for SE a/c cover
Last Post: Doc45
0 WTB parts for a '96
Last Post: slamtry
Old 17th March 2019
shanneba shanneba is offline
Default A different Oil filter test
Since it snowing today I found this web site and motorcycle oil filter test video while looking around on BobIsTheOilGuy.com
It is tests of BMW Motorcycle filters, such small filters for the BMW R1200GS
Filters tested:
HiFloFiltro
BMW OEM
Mahle
Mann
K&N
Volar
Mobil 1
Wix
Fram
Napa Gold
Super Tech
FLO Reusable
I thought you might enjoy the show on a snowy morning.
Web site:
Motorcycle Oil Filters in the Nuclear age
Testing data PDF:
Comparison And Test Using BestRestium
video of the test:
https://www.youtube.com/watch?v=A5W6...e=youtu.be&t=1
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 17th March 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Good info on oil filters. I was wondering tho, should the oil filter bypass lb. pressure match the ball and spring/ check valve on the bike, or should it be higher or lower than the bike's?
Old 17th March 2019
Sportster/Buell Year: 1988
Good info shanneba is the oil guy on here.
They do different things.
Old 18th March 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
Yet another good post shanneba! and yet again the filters we presume the best come out bad and visa-versa and anyone running the reusable ones seem to have wasted an awful lot of money!
What to use eh?
I did like the look of that latest Fram filter in another post, but it's not available over here.
I have a couple of Mahle, but i cannot see a drain check valve seal, so may have to cut one open and have a look see.
Maybe i'll just play safe and use the stock Harley filter for now.
Decisions, decisions, decisions!
Old 18th March 2019
I would try to contact Mahle and ask about the specs of the oil filter, they may provide the information to you.
https://www.cleviteorder.com/ASK/askmahle.jsp?askmahle=
You might get this type of info:
Code:
|                    Filter                     |     OC707      |     OC330      |
| By-Pass Valve Setting-PSI:                    | 120 kPA        | 120 kPA        |
| Anti-Drain Back Valve:                        | NBR            | Silicon        |
| Burst Pressure-PSI: (Operating Pressure Max)  | 900 kPA        | 1200kPA        |
| Max Flow Rate:                                | 30 l/min       | 30 L/min       |
| Nominal Micron Rating: (Ave. pore size)       | 32 + 2 micron  | 32 + 2 micron  |
| Filtration Area                               | 1380 cm2       | 1350 cm2       |
Old 20th March 2019
harley506d's Avatar
I contacted Mahle, but no response, so i cut one open.
A pile of junk i think.........
The filter medium was 7ft x 1.5/8 or 2150mm x 40mm for what use it may have been.
Old 20th March 2019
harley506d's Avatar
The reply from Mahle came through,
Date From Message
2019-03-20 MAHLE No anti drain back seal. By-pass setting 8-11 PSI - Burst Pressure 385 - flow rate 7-9 GPM - Micron Rating 21
Old 30th May 2019
Highly-Dangerous's Avatar
SPANIARD
Sportster/Buell Model: XL 883
Maybe the best Oil Filter in the world? Been using it for over 9 years and I will not go back.
http://kandpengineering.com/
S4 or S44 for Sportsters.
CLICK->>"Maintenance is as much art as it is science"<<-CLICK
Old 30th May 2019
Another "cleanable" filter option with 22 micron absolute rating.
https://shop.gopurepower.com/oil-fil...rt-pp8110.html
Old 30th May 2019
Hippysmack's Avatar
Which Mahle filter is that harley506d?
I'm starting a internal filter comparison in the pedia.
http://sportsterpedia.com/doku.php/t...ng_lubrication
