Last Post: painthuffer
0 so it's officially ended
Last Post: Nicktater
0 Xl???
0 old parts
0 Sportster drag bike
Last Post: Zip1
Last Post: robbie202
Last Post: ericfreeman
Last Post: FrankGS
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Samedward
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
Old 12th May 2019
rocketmangb's Avatar
Create a step on the pump gear without making it shorter
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 12th May 2019
just a ?
what is the end game?
taking the load off the chinchy key?
do not have parts in hand but think out the box
there are a couple of more ways to add security.
i know mr. hippy can come up with one for sure.
Old 12th May 2019
Hippysmack's Avatar
Hippysmack Hippysmack is online now
No pressure intended?
If you cut slots in both the pinion and the oil pump drive gear;
You are in fact locking them together.
That may 'help' just a little.
But the problem as I remember is the key on the pinion shaft is pretty short by the time it runs under the pinion gear.
There will still be that weak point there.
If you pulled the gears off, carefully extended the slot in the pinion shaft with a dremil,
You can install a second key under the pinion gear without the need to lock the gears together..
Old 12th May 2019
Envision if you will
Oil pump gear x section would be like this "L"
Pinion gear x section would be an "L" rotated 180 degrees counter clockwise
Forming a box so the 2 gears cannot spin independently
Old 12th May 2019
Hippysmack's Avatar
You'd have to add a spacer I'd think.
Cutting the fit would mean shortening both gears.
Then you have to fit the length as to not lose mating gear mesh.
I simply used a grid to create this so it's not scaled.
But it is a good representation of about how much length you'd lose.
Old 12th May 2019
You cut both gears
lay it flat and you see a half moon
You would lose some tooth area on the pump gear
Old 13th May 2019
Hippysmack's Avatar
Wouldn't you also lose some tooth area on the pinion gear?
You can't half moon it without cutting into some of the pinion gear teeth can you?
That takes away from the mesh at the cam.
That portion moves back against the now shorter pump gear leaving less pinion gear out front.. where the cam walks.
Depends on how deep you cut it to be effective... and affective.
Let's see some pics of the destruction if you try it.
Whatever you do to one gear, you have to do the opposite to the other and at the same equal distance inward.
Just as there is a machined flat surface between the 2 of them now.
So .020" length cut in any direction on 1 gear has to match to a .020" cut in the opposite centrifugal direction on the other gear.
That equates to a .040" loss in total length of the two.
Without a spacer, this loss in length will be seen on the gearcase cover side.
Looking at the wear marks on my old pump gear,
You may have remove or at least chamfer the back teeth on the pinion gear to keep the oil pump away from it.
Old 13th May 2019
darn no parts on hand when you need them
hippy's like a pit bull, i believe he has this one latched by the yang-yang. logic prevails.
think out the box and come further out.
Old 13th May 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
It is confusing but in this example the total loss of length is .020".
A full length section of the first gear sits in the .020" cut out in the second gear.
Old 13th May 2019
I dont have a pinion to snap a pic
It mad perfect sense when i saw the photo
