0 Sportster drag bike
Last Post: Zip1
0 Xl???
Last Post: robbie202
Last Post: ericfreeman
0 so it's officially ended
Last Post: FrankGS
0 old parts
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
Last Post: Nicktater
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Samedward
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
Old 19th May 2019
joes95bobber's Avatar
joes95bobber joes95bobber is offline
Sportster/Buell Model: MAGGY
Sportster/Buell Model #2: HAMMRD
Other Motorcycle Model: BEAR
Other Motorcycle Year: 2016
joes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond reputejoes95bobber has a reputation beyond repute
Default Falling out of 1st
Maggy is running a jockey shift set up (not sure if that matters here) and sometimes when coming to a stop she falls out of first gear. Kinda sloppy getting back into it and staying there. I eventually get her going, and it’s not all the time. I think it is something starting to fail. Before and wrenches come out, thought we could discuss it a bit.
If it was easy....anyone could do it....
Old 19th May 2019
Maggy is a 1995 XL 1200...thanks
Old 19th May 2019
mikeLI_77's Avatar
Could be the dogs on the countershaft starting to wear. I had it happen to my bike wear first and second would not stay in gear all the time and I had to change my 1st and third counter shaft gear if I'm remembering the numbers correctly to fix the issue. I would shift up and it would clunk like it went into gear but when I would let off the clutch it was like I was in neutral. Also when I was in gear it took almost no pressure of my foot on the shifter to pop it out of gear without using the clutch.
I added the baker smooth shift drum at the same time as well as changed out all of the spacers and bearings while I was in there. But it could also just be the detent clip coming lose and the tits on the detent plate are not engaging properly if it is hard to get it back into gear.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Old 19th May 2019
Hippysmack's Avatar
Hippysmack Hippysmack is online now
In the Sportsterpedia, here are some areas to look for wear when you go in.
http://sportsterpedia.com/doku.php/t...nsmission_wear
Sounds like a good inspection of all the parts are in order.
Egg shaped dowel holes are common to see and it will also help create slop.
Old 19th May 2019
COKEMAN COKEMAN is offline
COKEMAN is an unknown quantity at this point
check out this thread...
http://xlforum.net/forums/showthread.php?t=284920
Old 19th May 2019
mikeLI_77's Avatar
This thread has a good picture of what I am talking about just under my post.
http://xlforum.net/forums/showthread.php?t=2072870
Old 20th May 2019
Thanks for the links XLF. Had her out today for a good long ride. No issues so I think it is early in the wear down...i need to get her up on the lift one of these days to pop off and weld up the oil tank (again), so i will put this inspection on my list. Pic from today:
