Last Post: smilinbrad
Last Post: bklyngeezer
0 21 vs 22 vs 23 teeth sprocket
Last Post: Akdawg
0 tapped adjust
0 The salty debate thread.
0 $700 Ironhead ? Good value? depends who you ask
0 Kick starter resistance
Last Post: joes95bobber
0 Static timing
Last Post: ftwflh
0 05 carb rebuild no start
Last Post: randy3934
0 Starter solenoid short
Last Post: Yellowstone Kelly
6 ironhead turn signals
0 Smacked a deer last night
Last Post: Deimus
Last Post: BigMek
0 Handlebar risers
0 Spitfire motorcycle 2 into 1 Blaster
0 Hello New in the Forum
yeller1200, IronMick (78), painter (71), motobob883 (68), rickxx (66), MRCLEEN (48), Wetcheez (47), hello_shoes (40)
Old 20th May 2019
Pender1 Pender1 is offline
Pender1 is an unknown quantity at this point
Default New LED headlight bulb. Highbeam aim wrong.
Looking for some help here guys. I have a 2000 XL and my buddy has a 2004. We both picked up LED replacement bulbs from Hogworkz at bike week and got them stuck in. Despite the fitment being a bit tight, they fit and are bright as hell. I had to aim mine a little, but both turned out great. The problem came when we tried out the high beam. They light up the trees way more than the road.
It looks like you can adjust the bulb out some (makes it stick out in the reflector less). Is that the correct way to fix this or am I missing something?
CS slip-ons, Ultima 2000P, Hammer 1250 & forward offset a/c
Old 20th May 2019
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
The headlight bucket can be adjusted.
https://youtu.be/Pda_mXoeJk0
Old 20th May 2019
I did that already. I had to aim it a little to get my low beam correct, but the high beam is still way too high. It's like the difference between them is too much angle. To adjust my high beam down to where it needs to be my low beam would be aimed at the ground.
Old 20th May 2019
Sportster/Buell Year: 1988
If you mean a replacement H4 LED bulbs for tungsten filament H4, then that is probably your problem.
The LED light source is not in the same place as a filament, so the beam pattern can suffer from excess glare.
That is why is safer to fit a complete LED headlight unit as it will have the correct beam pattern.
Old 20th May 2019
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Other Motorcycle Year: 2000
I don't remember how or where, but I vaguely remember someone having to do mods to rotate the bulb 180 degrees
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 20th May 2019
Originally Posted by Four Speed View Post
If you mean a replacement H4 LED bulbs for tungsten filament H4, then that is probably your problem. The LED light source is not in the same place as a filament, so the beam pattern can suffer from excess glare. That is why is safer to fit a complete LED headlight unit as it will have the correct beam pattern.
Yes, a full light would be way better, but that's $35 vs $200. Figured this was good enough for now. There's a slot to move the bulb in and out of the housing, I'll see if I can find a good way to measure the old bulb depth vs the new LED and see if I can get it close to the same. I'll try to remember to take some pictures and throw them up when I pull it back apart.
This bulb has slots to mount it either way, but if you flip it 180, the high beam is aimed down. So that's not right either.
Old 20th May 2019
There are various lower cost/cloned LED headlight units available now - probably a better option.
Old 20th May 2019
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
No, not $35 vs $200...more like $35 vs. $40
https://www.amazon.com/Wisamic-5-3-5.../dp/B01DZU30S0
Old 20th May 2019
Thanks, but I trust a $40 full headlight about as far as I can throw my bike.
I have the bulb, it's what i'm using for now, just trying to get it aimed right.
Old 21st May 2019
F.W.I.W. while at "BKB's" we had a chance to compare his $40 Winsamic LED headlight to my way more expensive HD Daymaker. Using the back of his overhead garage door I was obvious that both bulbs were close in performance. The HD was a bit stronger with a wee bit better beam. Brian seldom runs at night while there are times I run all night. The slight improvement is good for me a and had it not been for the Insurance company buying mine I may have gone the less expensive rout.
