Last Post: darwin-t
0 Opinions
Last Post: Racepres
0 Static timing
0 Which cams ?
0 Fuel Pump Problems
Last Post: Lowe175
0 Front end restoration
Last Post: Dosmie72
0 Hello New in the Forum
0 Accelerator nozzle and idle not right
Last Post: hexnut
0 Kicker shaft question
Last Post: Captain Johnny
0 Spitfire motorcycle 2 into 1 Blaster
Last Post: Bmyers
0 The salty debate thread.
Last Post: Uberstorm
Last Post: XL1275
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
Last Post: Eddie65
Last Post: MikeBel
0 Kick starter resistance
Last Post: metal88
Last Post: Proteus
0 19" Tire w/23" Overall Diameter???
0 Smacked a deer last night
Old 22nd June 2019
WVDevil's Avatar
WVDevil WVDevil is offline
Sportster/Buell Model: XL 1200 Low
WVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant futureWVDevil has a brilliant future
Default Tail and turns wiring
Need some wiring help guys. Changing my rear lighting and trying to figure out the connections. Turn signals have 3 wires as does new taillight. I have a run/brake/turn module but it's wired in further upstream (worked perfectly with stock lights). Attached are stock wiring diagram and wiring portion of the instructions for signals and taillight. Appreciate any help!
Sent from my SM-G930V using Tapatalk
2009 Sportster XL1200L
[sigpic][/sigpic]
Old 23rd June 2019
Here's the Sportsterpedia section on LIGHTS:
http://sportsterpedia.com/doku.php/t...:elec03#lights
Is your R/T/B Module a H-D part (what #) or an after market one (what brand & #)?
If you are keeping the taillight distribution circuit board, then your 3-wire taillight should plug into connector [93A] using:
Pin#1 (Tail Light Lo-Intensity) ..... ORANGE Wire of new tail light
Pin#2 (Brake Light Hi-Intensity) ... RED Wire of new tail light
Pin#4 (Ground) ......................... BLACK wire of new tail light
Your new Turn Signals have separate wires for Hi & Lo Intensity display - But the distribution board expects to use a single-element bulb (Hi-Intensity Only)...
Based on your image of the instructions, to use the 3-wire TS units, you'll need to wire it as follows:
Connector [93A] as above - Pin#1 ... RED Wire from both new TS units
--- This is keyed power - always on with keyswitch ON - for Running Light
Connector [18A] using Pin#1 ........... BLUE Wire from new LEFT TS unit
---------------- using Pin#2 ........... BLACK Wire from new LEFT TS unit
Connector [19A] using Pin#1 ........... BLUE Wire from new RIGHT TS unit
---------------- using Pin#2 ........... BLACK Wire from new RIGHT TS unit
Old 23rd June 2019
WVDevil's Avatar
Hi, thanks for the reply. RBT module is Custom Dynamics GEN-SMART-TPU-XL, plugged in under the seat.
I was not planning on keeping any circuit boards, was going to cut and splice the wires. Using a connector would almost certainly be better but I have no local source for pins or connectors and don't want to wait for orders to come in.
My thinking is that with the Ness turn signals I can have either running lights or brake lights in addition to signals. Thinking I'll probably go with brake lights. Would prefer all 3, run, brake, turn but can't seem to figure out how to do that so one or the other.
Again, thanks!
Old 23rd June 2019
WVDevil's Avatar
If I wire it like I said, is the RBT module even needed? Should I just remove it?
Old 23rd June 2019
Without the circuit board, you can splice into the wires that come TO THE CIRCUIT BOARD (at 94B) - Here's the color connections again:
Your 3-wire taillight should connect to these wires:
HD BLUE wire (Tail Light Lo-Intensity) ..... ORANGE Wire of new tail light
HD RED/Yellow (Brake Light Hi-Intensity) ... RED Wire of new tail light
HD BLACK (Ground) ......................... BLACK wire of new tail light
Your new Turn Signals have separate wires for Hi & Lo Intensity display - But the R/T/B unit expects to use a single-element bulb (Hi-Intensity Only)...
HD BLUE wire ... RED Wire from both new TS units
HD BLACK wire ............ BLACK Wire from both LEFT & RIGHT TS unit
HD BROWN wire ........... BLUE Wire from new LEFT TS unit
HD VIOLET wire ........... BLUE Wire from new RIGHT TS unit
I think that R/T/B unit will try to run the Hi-Intenisty element of the new TS units as before - and it may work fine - if not, post back with what is happening...
Explore The Sportsterpedia - The Best Kept Secret on the XLForum![/QUOTE]
Old 23rd June 2019
WVDevil's Avatar
Thanks again. I'll twist some wires and try to get everything connected and see how she works before I cut the HD connector off. I'll let you know the results either today or tomorrow.
Old 23rd June 2019
i believe you do not have enough wires
check your other forum post
Old 23rd June 2019
WVDevil's Avatar
? Not enough wires?
Old 23rd June 2019
WVDevil's Avatar
OK, this is what works...
Tail
Orange to HD blue
Red to HD red/yellow
Black to HD black
Turns
Black to HD black
Left Blue to HD purple
Right blue to HD brown
Both purple to HD blue (misidentified as red in instructions)
Signals work for run, brake and turn. Thanks for pointing me in the right direction!
Old 23rd June 2019
Good to hear it's working - Wrench On...
