5 Red Shift cams similar to Jackhammer 570 ?
Last Post: Clevspeed
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
Last Post: Seek4aws
0 Year electronic diagnostics started
0 72 heads, do these look normal?
0 Hard saddle bags -
Last Post: Samedward
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
0 $700 Ironhead ? Good value? depends who you ask
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
  #41
Old 7th August 2019
steveolds steveolds is offline
steveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud ofsteveolds has much to be proud of
Status of project turn signal: Finished!! Diodes did the trick, and were easy to install. Many thanks
Old 8th August 2019
Good to hear, Steve...
Thanks for the update...
