6 ironhead turn signals
10 DEEP DIVER's JOKE
0 KR style bolt on hard tail for 78 XLCH
Last Post: 45Brit
Last Post: webman94
0 2015 883 with S&S 1200 conversion kit
Last Post: sportyone
Last Post: rocketnorton
0 93 883 Key switch and lighting
Last Post: bklyngeezer
0 Riding music
Last Post: XL1275
0 Significant exhaust pop at idle.
Last Post: firevf06
0 Cobra NH slipons
Last Post: Skeezix
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
0 The salty debate thread.
0 Hello New in the Forum
Old 8th July 2019
motogpfan82 motogpfan82 is offline
Sportster/Buell Model: 883
motogpfan82 is an unknown quantity at this point
Default LED Resistors or Relay Flasher?
I have my LED taillights installed and they don't flash when activated. I've read a couple of contradicting things on this, one I need resistors, two a flash relay will work or solution three that I just need to change all four signals to LED for them to work.The most common solution I've read is that I need resistors so I bought these.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Do I use one resistor for left and one for right, and second question, would changing all four to LED solve this issue without resistors? I have front LEDs but haven't installed them due to the other issues but if that solves it, then it would be great. Followup if I need resistors, when I do install the front do I then need two more for them or can the two for the rear be used? What about a flasher relay, would one of these solve all four turn signal flashing issues?
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
THANKS!
Old 8th July 2019
barry jubber's Avatar
barry jubber barry jubber is offline
Other Motorcycle Model: T140 Triumph Bonneville
Other Motorcycle Year: 1981
barry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to behold
I fitted a Custom Dynamics plug and play unit and all was good,
Old 8th July 2019
deuce460 deuce460 is offline
Sportster/Buell Model: 1200xlh
deuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud ofdeuce460 has much to be proud of
Hi
yes you need one resistor for each LED light,(but depending on the LEDs you may get away with two, one on each side) from the LIVE to GROUND, fitting the front ones too will not help, you can buy a flasher unit designed for LEDs but it depends on your model, i always use resistors and never have a problem, the value of the resistors depend on the LEDs but the ones you lised should be fine.
If you want to know why you need them, its because the flasher relay works on current draw from the bulbs and as the LEDs draw a lot less current the flasher cannot work properly. 25watt bulb @12v will draw just over 2 Amps,,,,0.36w LED @12V will only draw .30 Amps.
the resistors @6ohm will draw around 2Amps so the will equal the bulbs, the LED current is small enough to go un noticed
Old 8th July 2019
As a further note
Some LEDs lights draw more current than others, due to how there made,,thats why there is some confusion in other threads, if you fit the rear LEDs and a resistor for each one and it works then fitting the front LEDs should not require further ressistors
Old 8th July 2019
http://xlforum.net/forums/showthread.php?t=2070747
easy peasy
Old 8th July 2019
Here's the Sportsterpedia section on the Turn Signals (and LED conversion):
http://sportsterpedia.com/doku.php/t...3#turn_signals
Pair two resistors for each side - Connect one side of the resistor pair to the TS signal (which already runs to both bulbs & the indicator) on one side (right or left) - then connect the other side of the resistor pair to ground - This will create the 'load' for the TS Canceller so that it thinks there are still incandescent bulbs in the TS housings... (do the same for the TS signal on the other side)
Since (on each side) the Front & Rear TS bulbs & the Indicator bulb is already wired together, the resistor pair can be located any convenient place that you can reach the TS signal wire (BROWNwire=RIGHT / VIOLETwire=LEFT) and a solid ground... Under the seat is a commonly used location...
