Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Last Post: 1200CustomHD
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
5 Red Shift cams similar to Jackhammer 570 ?
Last Post: Seek4aws
0 Year electronic diagnostics started
0 72 heads, do these look normal?
0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
0 $700 Ironhead ? Good value? depends who you ask
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
Old 19th July 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Exclamation Oil Filter
63796-77A, This is the HD # for the 30 micron oil filter that is used for my Sportster. There is a part # change update, 63731-99A and this is a 5 Micron filter. Seems to me that a 5 Micron filter is going to pass more unfiltered oil, until it reaches operating temps PLUS slow the oil return in general. I'll stick with the 63796-77A filter, don't want to sieze a crankpin or something because of lack of oil! Oil filters are just as important as the oil you choose.
Old 19th July 2019
rocketmangb's Avatar
People still don't understand the bypass valve !!!!
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 19th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
9+ gallons a minute isn't going to starve the motor for oil. Isnt the new HD premium used for the Sporty and BT 5 micron?
Old 20th July 2019
It certainly is !
I run the Napa 7148
Old 20th July 2019
Toejam503's Avatar
I understand how a by-pass valve works, maybe I should have said "Unfiltered oil", but by-pass valves, all seem to have different pressures to open them. So, if you use say an AC Delco oil filter, it takes 11-16lbs of pressure to open it, where a Harley specific filter's by-pass valve only takes 4-7lbs of pressure to open. Too much by-pass pressure, I think, leads to wet sumping or overflowing oil tanks and lack of oil getting to where it needs to be. If I'm wrong point me in the right direction....please.
Old 20th July 2019
Pressure "Differential" is 8 PSI not pressure !
IE" 30 PSI inside and 25 PSI outside the valve is closed
Old 20th July 2019
Toejam503's Avatar
So it's pressure DIFFERENCE not actual pressure.....Thanks Rocketman!
Old 20th July 2019
dieselvette's Avatar
You are correct about the bypass opening if the filter is restricted. I'm not sure how one can tell if it's too restrictive or not, any ideas?
The oil pump will move x-amount of volume per RPM, no matter where it goes, it WILL move at a fixed volume flow rate - no more, no less. If the fluid doesn't have a place to go then the pump will catastrophically fail (blow up). The only way the pump would move LESS oil is if it doesn't have any coming in, and air comes instead.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 20th July 2019
...So your concerns about more bypassing, with a "tighter" filter, may be valid. (Due to the fact that the oil pump will still move the oil volume, wherever it goes). Someone with knowledge of oil & micron ratings should look into that.
I'm not one to blindly trust other's engineering either, but I do think it's safe to assume that HD has thoroughly studied myriad options for oil filters and engine longevity over the years. I'm just going to keep using the same NAPA (Wix) filters that I always have, because that's been working fine for me and everyone I know.
Old 20th July 2019
Napa Vs HD Super Premium 5
