0 Opinions
Last Post: Racepres
0 Static timing
0 Which cams ?
0 Fuel Pump Problems
Last Post: Lowe175
0 Front end restoration
Last Post: Dosmie72
0 Hello New in the Forum
0 Accelerator nozzle and idle not right
Last Post: hexnut
0 Kicker shaft question
Last Post: Captain Johnny
0 Spitfire motorcycle 2 into 1 Blaster
Last Post: Bmyers
0 The salty debate thread.
Last Post: Uberstorm
Last Post: XL1275
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
Last Post: Eddie65
Last Post: MikeBel
0 Kick starter resistance
Last Post: metal88
Last Post: Proteus
0 19" Tire w/23" Overall Diameter???
0 Smacked a deer last night
Old 19th August 2019
42f67n 42f67n is offline
42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light42f67n is a glorious beacon of light
Do they fill the same hole that the air goes in?
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Yes, drain and fill through the air hole.
rejeanprimeau's Avatar
Why use a rig to empty the shock, I just install them upside down with the air hose sending the oil outward in old water bottles and go for a ride.
Old 20th August 2019
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: XL1200CX Roadster
Sportster/Buell Year #2: 2017
b0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond repute
dyna shocks will not work in a sportster. spring is too heavy because the dynas have the shocks in a higher angle. vrod ones are even worse.
Old 28th August 2019
What air pressure do I set the shocks to? For solo and 2 up also what the max air pressure?
I got Genuine Harley Davidson Touring Air Shocks Fits 09-16 Models 54662-09
b0fh's Avatar
35 psi max... usually 0psi solo, 15 2-up
spitfirechopper's Avatar
spitfirechopper spitfirechopper is offline
Sportster/Buell Model: ironhead xlx
Sportster/Buell Model #2: 1200 custom
Sportster/Buell Year #2: 2005
spitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud of
i run dyna shocks on my sportster, needed some shocks in a pinch and they were cheap.
I can tell you that 0-60mph they are uncomfortably stiff 60-100 they are downright dangerous.
