0 New to me 55kh
Last Post: thefrenchowl
0 S&S Super E Carb
0 AGM battery for 76' XLH
Last Post: JonesL
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
0 so it's officially ended
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
Old 7th February 2005
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Rode some more over the weekend before the Super Bowl. Lots of snow run off puddles that dirtied up the nice wash job the dealer gave my ride, but it was fun!! Being an Eagle fan I won't ride again for a day or two until the urge to drive off a bridge passes! Anyway, the weather was in the high 40's on Saturday and I rode a known distance, 15 miles to my work and back and it appears the reflash did correct the odometer. Also, my bike ran great this time probably owing to the warmer weather. Once up to temp the reflash is noticeable to me on the lower end. Seems to pull harder starting out than before. Also, for some reason my exhaust sounds different??? But different in a GOOD way! Throatier, I guess is how I would describe it....probably just my imagination. Someone asked if anyone had the reflash done with Stage 1 mods. That would be an affirmative. SE II slashdowns, SE hi flow air cleaner and dyno jet upgrade on my ride. Seems like a good thing to do, (the reflash).
Wardog's Avatar
Wardog Wardog is offline
Wardog is an unknown quantity at this point
I wasn't feeling good a 0330 hours this morning so I decided to take a sick day. Along about 0930 I was feeling better and thought that a ride might make me feel better. Decided to get the reflash done to the ICM. Bike was difficult to start, had to let it warm up longer than usual and had carb farts going over to Eastcoast Harly. Took them about 30 minutes and I was back on the road. My impression is that the bike runs stronger and the speedo is more accurate. Will have to check it against my GPS on a warmer day. Felt much better after the ride. Weather got to 62 degrees toaday. Have a good one back to work tomorrow.
Old 13th February 2005
KLars KLars is offline
KLars is an unknown quantity at this point
All-
I recently had the ICM on my 2004 XL1200C Stage 1 updated at the dealer.
I had P/N 32478-04 to start with.
They reprogrammed with P/N 32622-04A.
Is this correct?
For others that had M-1162 completed that had 32478-04 originally:
What was the P/N they reprogrammed with? 32478-04A or 32622-04A?
Thanks a bunch...Kevin
nutsy nutsy is offline
Sportster/Buell Model #2: 1200 custom
nutsy has disabled reputation
im pissed i didnt get a recall on this. 1st thing monday ill be on the phone with dealer.
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
Save your breath.... It wasn't a recall, it was a service information bulletin. They are 2 different breeds of cat.
LuxBlue's Avatar
P/N 32622-04A is the program # I ended up with, it's the most current.
Turbota's Avatar
Turbota Turbota is offline
I have the SE ignition module P/N 31759-04 in my bike. That's the module with the 7,000 rpm rev limiter and decreases timing 5 degrees when your at wide-open throttle.
I guess the re-program you are all talking about would not be done on 04 1200 since I have the new module?
Ron,
04 XL 1222R
Thanks for the confirmation LuxBlue.
Kevin
Old 14th February 2005
Gone Gone is offline
I just had the flash done. It most definately cured the hiccups. I don't know about a smoother idle. Maybe, but I couldn't swear to it. I definately noticed the spedo difference. I highly recommend this based on the colc hiccup problem alone. I used to have to ride a much longer time with the choke pulled out. Now it warms up just like my '02 did.
Old 15th February 2005
i called dealer about this reflash and he said he knows nothing about it.what am i supposed to do now.it says when u take bike for service they will fix but mine never did.
Similar Threads
Review for Mustang seat #76440 klamen Product Reviews 22 24th July 2007 19:02
2005 30th Anniversary Honda Goldwing Review wagoneer12 Product Reviews 16 31st May 2005 08:54
HD gloves review engine Product Reviews 2 8th April 2005 03:22
ICM Reflash Idle Speed Increase? DM-SC Rubber Mount Sportster Motorcycle Talk (2004-2006) 3 15th March 2005 05:32
