0 Need Tuning Advice 1275 Kit 560 Cams
Last Post: owlsplace
Last Post: rocketnorton
0 Rear sets?
Last Post: bordens
0 so it's officially ended
0 Hello from LA area
0 Mustang Seat FS
0 Round Air Cleaner Poll
0 Nup 1009 (Bearing)
Last Post: Racepres
0 Generator light q
Last Post: BigMek
0 Oil Bag?
Last Post: randy3934
0 S&S Super E Carb
Last Post: Full-Bore12
0 New oil tank
0 04 cracked oil tank
0 The Sport(ster)ing Life
Last Post: Akdawg
0 Xl???
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: Nitro57xl
0 Fuel Pump Problems
Last Post: BigMek
Old 5th May 2006
xena's Avatar
xena xena is offline
Assistant Administrator
Glad you solved it but I'd be looking for a new
dealer because they should know enough about
these bikes to know just what to look for and
they should have found the problem.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 5th May 2006
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Post 60-70 Ft-Lbs.
Originally Posted by 883 custom
I'll check mine out as well, anyone know the torque for this nut?
From my '04 Service Manual
Old 5th May 2006
OldFenderGuy's Avatar
OldFenderGuy OldFenderGuy is offline
Other Motorcycle Model: Dyna WideGlide
Other Motorcycle Year: 1996
OldFenderGuy is an unknown quantity at this point
From the Clymer Manual;
.. apply Loctite 243 to the threads, tighten the front engine mount bolt to 60 - 70 ft.lb (82 - 95 Nm).
[i]2005 Sportster 1200C - Lava Red Sunglo
1996 WideGlide (FXDWG) - Metallic Lava Red
2003 Anniversity FatBoy - EFI, SERT, Dyno Tuned
1981 "Sturgis" Shovelhead (Semi Retired)
1949 Panhead Custom Chopper (More Than Semi Retired)[/i]
Old 5th May 2006
883 custom 883 custom is offline
883 custom has disabled reputation
Thanks for the torque info! Gonna check this bolt as well as the rest of the motor mounts.
Old 6th May 2006
thunderpaw's Avatar
thunderpaw thunderpaw is offline
thunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the rough
I have noticed an increase in vibes on my '05...I will check it this weekend...thanks for the tip!
Kim
Old 6th May 2006
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
Sportster/Buell Model: 883
gronk62 has disabled reputation
Thumbs up
I just went and checked mine and sure enough it was loose.
It took about 3/4 of a turn to tourqe it up again.
I'm about to go for a ride so I'll see if there's any reduction in vibration. I would expect there to be some.
Thankyou Ron for bringing this to our attention.
I'll make this thread a sticky as it may be a common issue for rubbermount owners.
Old 6th May 2006
gronk62's Avatar
Thumbs up
Ok, just got back from my test ride.
Noticably reduced vibration through foot pegs and bars.
Mirrors stay clearer.
Old 6th May 2006
MusclePump's Avatar
MusclePump MusclePump is offline
Sportster/Buell Model: 883L
MusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really niceMusclePump is just really nice
Nice
Old 6th May 2006
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
Seems like i felt a little vibration in the pegs at 67mph tonite while riding home. I have a little over 15,000 0n my '05, out to the garage i go! Thanks, it's great to learn something new everyday on the forum!
Old 6th May 2006
Tucson_Tim Tucson_Tim is offline
Tucson_Tim has disabled reputation
Gonna check mine this weekend. Thanks man!
