0 AGM battery for 76' XLH
Last Post: JonesL
0 S&S Super E Carb
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: Nitro57xl
0 so it's officially ended
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
Old 7th October 2016
sportsterdoc's Avatar
64physhy: I replied to your PM when I got home from my 300 mile commute.
56 is incoming power for load
A jumper from 56 to 30 provides power to coil
56a & 56b are alternate loads
For the coil to function, S appears to be to ground, via a momentary contact switch/pushbuton
hey doc, I think edster needs your expertise. I shouted him over to you, got charging issues.just building purlings and installing them with roof panels no time to help him.
I will try contacting him.
Appears work negotiations *** are done for the day and Fridays are usually quiet (at least for electrical questions).
***I am so not yet retired!
