0 so it's officially ended
Last Post: ericfreeman
0 New to me 55kh
Last Post: joes95bobber
0 Oil Bag?
0 Hello from LA area
0 Need Tuning Advice 1275 Kit 560 Cams
Last Post: owlsplace
Last Post: rocketnorton
0 Rear sets?
Last Post: bordens
0 Mustang Seat FS
0 Round Air Cleaner Poll
0 Nup 1009 (Bearing)
Last Post: Racepres
0 Generator light q
Last Post: BigMek
0 S&S Super E Carb
Last Post: Full-Bore12
0 New oil tank
0 04 cracked oil tank
0 The Sport(ster)ing Life
Last Post: Akdawg
0 Xl???
Last Post: 1200CustomHD
0 Fuel Pump Problems
View Poll Results: Why I don't have a HID headlight
I'm cheap 141 43.25%
I can't figure out how to install one 34 10.43%
I like dim headlights better 13 3.99%
I'm afraid of my shadow 11 3.37%
Can't find one I like 34 10.43%
My bike's not fast enough to need one 13 3.99%
I already have one 49 15.03%
I just don't need that crap, thanks 85 26.07%
Multiple Choice Poll. Voters: 326. You may not vote on this poll
Old 5th June 2010
rottenralph's Avatar
I messed with my turn signals for 3 hours today? 1 wire can sometimes be more problem than it is worth. Where does this magic wire go???
Old 5th June 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
The main power wire needs to run from the ballast to under the seat. I hooked mine up to the lighting breaker. All the rest of the wires are just plug and play.
Old 5th June 2010
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
Sportster/Buell Year: 0
jimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud of
Originally Posted by pcwolf View Post
Don't need to stuff five pounds of electrical crap into my stock two pound headlight nacelle since I don't overdrive my lights at night as it is.
Sorry that wasn't a polling choice
-Phil
Yorktown
I couldn't find a choice that made sense to me but the above sums up pretty nicely what should have been a choice.
Old 5th June 2010
Originally Posted by biknut View Post
What's your excuse?
Check all that apply.
Looking at the pics, wouldn't aiming the light correctly yield almost the same results?
Old 5th June 2010
biknut's Avatar
It is true that adding anything to a Sportster and making it look clean is a challenge, but it can be done.
Old 5th June 2010
biknut's Avatar
If you mean with a halogen bulb the answer is no. 1100 lms vs 3200. There's no contest.
Old 6th June 2010
Ok, so it's not just a wider beam but it's much brighter too?
Is blinding oncoming traffic at night really the best thing to do?
A halogen can be put to a reasonable low beam in the city and high beam on the open road so you don't blind everyone else on the road.
This one seems to have 2 modes, blind them and burn out their retinas.
It's bad enough that people don't know when to turn off the high beams with regular halogens.
Old 6th June 2010
biknut's Avatar
I promise you it doesn't blind anybody. The bulb is very well shielded. The light pattern is exactly the same as my halogen. I've never been flashed once in the last 2 years with this set up. A few years ago I was running a 80/100 watt halogen and I got flashed often. It wasn't as bright as this light, but I wasn't shielded as well (at all).
Old 6th June 2010
Banned
Why I don't have a HID Headlight Poll
because there is already this active HID headlight poll
Old 6th June 2010
biknut's Avatar
Yeah it's active alright.
