7 It's Nibelungen's Birthday!
5 Jiffy Standing
Last Post: 83XLX
0 Modified heads
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
0 tire time
Last Post: 2cvandy
Last Post: Rocker52
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
marklocklear marklocklear is offline
marklocklear is an unknown quantity at this point
Default Remote oil filter
Hey guys. Adding a remote oil filter to my 77 Sporty. Here is a pic of the filter housing:
https://photos.app.goo.gl/wu27sNzk4W6XoK9K6
Which of these nipples on the right (the one closets or farthest away) going into the filter housing should be receiving oil from the oil pump vs. going back to the oil tank?
Also here are a couple of pics of how I am planning to route the oil lines through the frame:
https://photos.app.goo.gl/nXawHaM2LbkeWutL9
https://photos.app.goo.gl/qis47v17NdtVvkxPA
Any issues with the routing or is there a better way to do it?
Here is the routing at the filter pad
To easy!
For any spin-on (cylindrical) filter dirty oil goes in to the outside of the media and clean oil comes out the center.
This is due to the physics of the filter media, so debris can fall away from the media and also so any pressure difference would balloon the media and debris might be pushed through the media if it ballooned.
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 2014
Sadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud of
Next time you might look at a unit for an '83 shovel. its a smaller, neater setup...or make one yourself.
I've often run with the devil, but I've never made any deals....
