7 It's Nibelungen's Birthday!
5 Jiffy Standing
Last Post: 83XLX
0 Modified heads
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
0 tire time
Last Post: 2cvandy
Last Post: Rocker52
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
rickthrash99 rickthrash99 is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1984
rickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to allrickthrash99 is a name known to all
Default brake lines swap
whats up guys i got a problem finding out how to do the swap on the female fittments to banjo, will it work?? whats your guys set up? i have an 84 disc brake set up, its one of the final steps to complete my hard tail build
pictures work.
you can get all kinds of fitting from russel. i converted years ago so i only have to worry about hose and not fittings, sourced from amazon and was reasonably cheap.
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Scott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud ofScott has much to be proud of
Are you talking about the issue I had with my ‘81 IH? All the brake lines had automotive style flare endings. The thread on the fitting is 3/8-24, the same as a an SAE banjo bolt. I just had to very carefully drill the m/c and calipers to deepen the hole and get rid of the female flare piece. Used a combination of brake cleaner and compressed air to get rid of all the aluminum shavings. Now I can use standard and easily available lines and fittings (that work with both 3/8” and 10 mm banjo bolts.
Make sense. I could explain it better with photos.
thanks bustert iwill check that tonight
scott yesss thats what im talking about it had automotive flare style, thanks scott id like that set up you are talking about
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant future
Ebay is a great place for pics and low priced fittings and lines. Adapters to match anything to anything else (US to metric, brake line flare to anything else) are plentiful.
