7 It's Nibelungen's Birthday!
5 Jiffy Standing
Last Post: 83XLX
0 Modified heads
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
0 tire time
Last Post: 2cvandy
Last Post: Rocker52
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
CDeckner CDeckner is offline
Sportster/Buell Model: XLH883
Sportster/Buell Year: 1989
CDeckner is an unknown quantity at this point
Default Mainshaft bearing
What’s the best way to drift or press in the right side case mainshaft bearing for the transmission? I want to make sure I get this replaced right and not wonky.
mikeLI_77's Avatar
From post#172-179 may be helpful to you of this thread.
http://xlforum.net/forums/showthread...1677275&page=5
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Kinda helpful in a way but I’m trying to fix a 4 speed
Old 5 Days Ago
have you tried the two sockets and all thread rod? press out/in
could use socket and heavy washer also
Old 5 Days Ago
I ended up using a couple of bearing and race drivers and a long bolt to press it in.
Old 5 Days Ago
Sportster/Buell Year: 1988
Is it still binding?
Old 5 Days Ago
It is. I just ordered a zippers trap door to eliminate the trap door as the issue. I was going to upgrade this anyway.
Old 5 Days Ago
Let us know what happens with the zipper. Best of luck.
