0 New England 2018
Last Post: Boudwood
0 Hi tech bike moving aid
0 Mikuni Stuff I've Ignored, Till Now!
0 Relatively Interesting Road Sign
Last Post: mrmom9r
0 Who's still riding???
Last Post: paulc
0 Metal Polishing
0 Ice tire
0 touchy feely sissy bar emotions poll
Last Post: mikesova
0 When Were You Born?
Last Post: Henry007
0 THE Trainspotting Thread
0 Lithium battery earthx
Last Post: Tucsonmax1
0 My 1978 Ironhead
0 88ci Sport Rod
Last Post: rubine
0 Been gone a while
Last Post: Screw Loose Dan
0 Mid controls on a Custom
Last Post: kaveebee
0 Brake shoe removal/installation tool
Last Post: JackPrice53
0 Another November. . .
0 Spokes and dual disc
Last Post: PetesPonies
0 Value of a Boattail?
Last Post: Harleydave
0 Paper gasket
Last Post: sdsbassist
0 Quick and probably stupid question
RISport, Sleeper, Chaoszen (65), wojmc (63), Deicer18 (61), PhilR1957 (61), Bikerchk (61), bblbbl (43), 883Hugger (34)
Tator's Avatar
Tator Tator is offline
Sportster/Buell Model: ironhead sporster
Sportster/Buell Year: 1967
Tator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud ofTator has much to be proud of
Default Question on a transfer valve
I was reading a post by Mopartnut73 and you guys were talking about a transfer valve that sucks the oil out of the primary. I have a 1967 XLH and 1960 XLCH and a 1953 K model. In the two ironheads, I am running a primary oil that I buy at my local motorcycle parts place that is more like a transmission fluid. Is this being mixed back and forth with my oil? I always thought those two systems were separated.
doodah man's Avatar
yes the two systems are connected and can/will mix engine and primary oils. the primary wasn't separated until 1977.
Tator's Avatar
Thank you very much for the quick reply. So this means I need to change oil in both of these bikes and put strait motor oil in the primary.
doodah man's Avatar
right. strait motor oil, or even 20w50 if it gets cold where you are.
paulc paulc is online now
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
This thread is worth a read:
http://xlforum.net/forums/showthread.php?t=581947
Post No 40 was what finally got the penny to drop for me.
Paul
If someone blocked off the valve, and the sprocket seal is working as intended (sealing), then they are separate compartments and you can run whatever you want in each.
If the transfer valve is in place, then engine and primary oil mixes and the same oil should be in each.
If you want to do something, you’ll find a way. If you don’t, you’ll find an excuse.
good point GA.you shouldn't assume either way.only way to be sure is to verify if the transfer valve is functional or plugged.
8ball's Avatar
8ball 8ball is offline
Sportster/Buell Year: 1973
Sportster/Buell Model #2: xlch stroker
8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of
all correct info im reading here. if/when you open the primaries post a pic of each we can tell you if they appear stock/functional.
what wasnt addressed. ** i dont know a lot about this, im only posting what i know**
the k model- it also transfers. the details of how i dont know well enough to post about but the same primary and engine oil should also be kept the same.
"ya...i saw a guy do this once... " -DR DICK
Tator's Avatar
I have read all the posts on the thread up until this a.m. I was not having any trouble with the bikes but last time I changed oil in them I put the more modern transmission fluid in the primaries. So today I went out and changed oil in both bikes and cleaned out both primaries. They both have the valves in them they both look clean so I put them back together with strait oil. Thanks again everyone for all the info it was a very interesting read. I can see both sides, if it is a PCV valve or a transfer valve, they both make since.
