0 Cut Wiring, no spark.
Last Post: Jollly Rogers
0 Proposed clutch spring improvement0
Last Post: Prof Rene
0 Another poser sentenced
Last Post: Bone
0 Gravydog crashed again.
0 Shotgun Porn
Last Post: TonyGall
0 Happy Birthday IronMick!
Last Post: stalkie
0 National Guard
Last Post: jharback
0 Hello from 1970s Wisconsin!
Last Post: Redbeard2
0 Shovester Sighting
0 Clutch gone out of adjustment seems like a lot
Last Post: jordan1200
0 Oil returning from rocker boxes
0 Hello from Tacoma
Last Post: CBryant
0 19 inch mag wheel questions
0 Are you a Vet?
Last Post: farmall
0 New T Shirts
0 77 xlh pinging noise left side
Last Post: Beazer
0 The Official New Forty Eight Thread
Last Post: Turbo Sporty 48
Last Post: jcn59
0 13 3/8" Emulsion Shocks on Xl1200c
Last Post: Spokane2303
0 BowlingGreen Fall races
Last Post: tigger
PlanB, Cuco6924 (72), 1200sporty (61), iron68 (47), LifesHarlequin (34), mattosm (33)
Old 23rd April 2018
doodah man's Avatar
Originally Posted by gpydeski View Post
Yeah I looked at your picture again. Those pegs should be on the frame where I said. It looks like the mount broke off and someone drilled through the primary cover and mounted it there. Where is the other side mounted?
'77 up left side shift are all like what are in heff's pics. the foot pegs mount through the engine cases, not attached to the frame like '76 and earlier.
Old 23rd April 2018
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
chevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to behold
That stand is aftermarket.
I'm sure that has something to do with it...
I would try an OEM one or modify the aftermarket stand before modding the frame, if thats an option.
Taller shocks will exaggerate the lean.
Old 23rd April 2018
Originally Posted by Heff View Post
this looks like a broken case casting here? at the bolt boss for the primary cover.
Old 23rd April 2018
Heff's Avatar
Heff Heff is offline
Sportster/Buell Model: Xlh
Heff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of light
Scared the crap outta me, bruc!
Had to stop dinner and come back to to the shop...no crack. Just a shadow from a casting edge. Shew.
77 xlh. Some mods...some visible, some unknown
Old 24th April 2018
MXHD55U MXHD55U is offline
Sportster/Buell Year: 1969
MXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant future
Kickstand lesson one:
the kick stand if for the bikes weight only. Don't sit, lean or in any other way put weight on the bike when it is on the stand. As my ol mentor Jack Moss used to say, if you need to sit get a chair or go for a ride
Old 24th April 2018
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
It looks like the stop is wore out. So I'm going to add some metal there and reshape that. Should take care of it
Aaaaa Ha, very good, much like I suspected.
Take pre-cautions if you are going to do any electric welding for the build up of iron on that stop.
Looks like ya could use a new spring too.
Old 24th April 2018
chevelle's Avatar
Oh ok, how should we kickstart our bikes?
Old 24th April 2018
Heff's Avatar
Yea, that spring is sprung. Gonna take care of that today.
Unfortunately, the only welders I have access to are wire feed, so I'll find out how well that works
Old 30th April 2018
class of 82 class of 82 is offline
Sportster/Buell Model: sportster xlh
Sportster/Buell Year: 82
Sportster/Buell Year #2: 82
Other Motorcycle Model: KZ 550
Other Motorcycle Year: 82
class of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to allclass of 82 is a name known to all
I suggest having a real close look at the frame/mount area of the frame tube itself to make sure it is not bending/collapsing.
my 82 frame collapsed in on itself and started to lean over till the stand pivot end hit the case. then the case stated to leverage it till it popped a piece of frame out along with the stand mount.
used a nice fat steel bolt to fill in the area of the frame welding the bolt and the KS mount back on as I filled it all back in solid.
I made sure it was leaned over where I wanted it when I went at the mount.
this is all after "oh! I just move it over an inch and weld it back on" it went 3 days and popped another plug out of the tube. I filled it in with a steel bolt to make a slug then weld up solid.
I guess my 82 frame is a little thin/rusted but holds up now after a slug and re-weld.
