Last Post: andy2175m4
0 Carb ???
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 Q cams in 73 xlh ??
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
tires
  #81
Old 20th June 2014
cycowrencher's Avatar
cycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond repute
Hurry up and get better enough to finish the maintenance on your bike and get some miles in. I can feel your pain, i just had a low speed get off on Monday. I was stopping for a red light and the front washed out in a puddle of antifreeze. Slammed me pretty good. FF and armored jacket kept the damage to a bruised hip and twisted knee and ankle. Minimal bike damage. Still limping myself.
Sent from my LG-LS995 using Tapatalk
Old 20th June 2014
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
Antifreeze is crazy slick, that is why roadracers are required to run water. In my experience you hit the ground just as hard in a ten mile an hour low side as in an eighty mile an hour one and you have less opportunity to save it. You might get ground up less depending on the gear you have on, but the impact with the ground is very comparable.
Old 22nd June 2014
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Model: FXDL Low Rider
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
Sorry to hear about yer get-off cycowrencher antifreeze is nasty sh!t hope you get better quick, you may not have got as busted up as me but twisted knee and ankle is no treat.
Myself... I'm walking pretty good this last week, though the Latin dance competitions will have to wait another month or two. Meanwhile I'm getting some good riding in... did about 700 miles last weekend on a Friday 13th run with IronMick and sportsterpaul
Only minor work on the bike lately, front pipe was slapping the footpeg and I fixed that by moving the mounting clamp below the frame bracket which provided nearly an extra 1/4 inch of clearance... perfect! Remaining maintenance and accessories will need to wait on the tight budget. Bike is still a long way from where the Sportster was. Handling is, well... lacking. Minimal storage in the tiny hardmount bags that came with it. Brakes still need overhaul. And I really miss a good useable windshield, anything over 60mph just sucks with a half helmet and sunglasses. Forks really need a fluid change and tuning, brake dive is atrocious.
John from Windsor Ontario
'00 FXDL
Old 22nd June 2014
Don Burton's Avatar
Don Burton Don Burton is offline
Sportster/Buell Model: XL 1200 Gone
Don Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond repute
Originally Posted by Bone View Post
I and many of my friends have locked and released on a Harley. You are right that you risk a high side, but long and low buys you a second or so to react before that is guaranteed.
You're right! Over 30 years ago I locked my rear and had to release or I would have become part of someone's grill! That said, the danger of high siding is there when you release. I was fortunate as I had no time to think, rather all I could do was react and use my reflexes.
Old 22nd June 2014
Don Burton's Avatar
Originally Posted by NCWSporty View Post
For me, I have always put premium sticky(er) tires on many bikes I've owned. The return is confidence in traction. The diminished part is they wear out quick!
I am sporting a broken leg right now so I can't roll out my bike at the moment, but here are a couple of pics showing my direction with tires.
I have lighter aluminum rims than stock steel, my front tire is actually downsized from stock width and my rear tire is light on load rating for the sportster, not a heavy tire.
There are always work arounds!
The profile of those tires looks downright radical as compared to the somewhat square tires that one usually sees on Sportsters. May I ask what brand and type tire they are? Will they fit the stock aluminum wheels of rubbermount Sportsters? Tires like that could make one look for a suspension upgrade really quickly and could make these bikes quite a bit livelier in the corners even with their excessive weight.
Old 7th July 2014
NCWSporty's Avatar
NCWSporty NCWSporty is offline
Sportster/Buell Year: '13
NCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to behold
Sorry Don, been away for a while. Michelin Pilot 170/60 in the rear and a Michelin Scorcher 120/70 for a V Rod in the front. Both radials, but not quite a match compound-wise (the rear is softer), plus the load rating is on the light side for a sportster.
They may not fit a stock set of wheels properly - these rims are 3.50 & 4.25 19"/17" Sun rims from Buchanans.
I think my bike turns in decent & goes round corners good. Its stable anyway.
Fire the motor, twist the throttle, life is good
