0 Carb ???
Last Post: andy2175m4
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 Q cams in 73 xlh ??
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
d401, dunlop, tires, wheels
Old 16th August 2015
cb35717 cb35717 is offline
Sportster/Buell Model: XLC 883
Other Motorcycle Model: Honda CB360T
Other Motorcycle Year: 1975
cb35717 is an unknown quantity at this point
Default Tires
I have an 05 xlc with just over 30k and needing a new tire on the rear. HD calls for Dunlop D401 and I am currently running a Dunlop D404. Has anyone run anything else with great results? I'm getting around 10K on rear tires.
Tom's Avatar
Tom Tom is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: '84 FXE Super Glide
Tom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond repute
In my experience if you're not going to change both tires you should stick with what you have or go with the D401. My reasoning is that other manufacturers tires are going to have a different profile than the remaining Dunlop and that could give some strange handling. Once I fitted some Avons to a Low Rider I had and the handling was completely changed, not bad just different. I've read and believe that Harley works closely with their tire suppliers to get the right handling characteristics.
einheit 13's Avatar
einheit 13 einheit 13 is offline
Sportster/Buell Year #2: 1997
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to beholdeinheit 13 is a splendid one to behold
Everything besides a dunlap....Avon AM and AV series, Pirelli, Bridgestone, Kenda, Shinko, IRC....never ran a Metzler. Anything is an upgrade to the D40X series. And the handling will increase.
Change them how you want without issues. Don't worry about brands or tread patters being mixed.
Life may begin at 30, but it really interesting around 150!
Old 22nd August 2015
SportyXL's Avatar
SportyXL SportyXL is offline
Sportster/Buell Model: XLH1200C
SportyXL is an unknown quantity at this point
Had a new Dunlop put on front by dealer when I bought the bike. Rear was almost shot. Dealer wouldn't put one on. Put a Michelin CII on the rear and noticed a big difference. I haven't tried any other brands so I have nothing other than the Dunlop to compare to. Didn't notice anything bad from having different brands on my '02. Only thing I noticed was a lot less vibration from the rear. Just felt a lot smoother but made the front feel a lot more vibration.
