Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
12 I caught a carburetor THISSSSSS rare
Last Post: fafcpa
0 Indicators not flashing
0 Gear indicator missing
Last Post: mrmom9r
0 1975 Sportster
Last Post: IronHeadRon
0 Transmission drain plug
Last Post: mvent
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
Old 6th October 2016
jordan1200's Avatar
Default Thunderstorm Heads 16827-98YB and 16797-98Y
Can anyone supply an OEM parts list for my heads?
Sent from my Nexus 6P using Tapatalk
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
Old 7th October 2016
ReddTigger's Avatar
This is one, but they're not local.
Twin Motorcycles
States I've Ridden in
71.3 hp 70.8 tq
jordan1200's Avatar
Thanks I just going a copy of a buell parts catalog in PDF format but parts are another story
This from the Hammer Performance website:
http://hammerperf.com/ttxlheads.shtml
98-02 Buell Thunderstorm Heads
Contrary to what you might hear, the springs, retainers, locks, guides, locaters, and valve stem seals are all standard HD pieces in a Thunderstorm head, the exact same part number pieces that you'll find on every other Evolution Sportster and Big Twin head of that era. The Thunderstorm heads do not have any special hardware other than the larger diameter valves.
__o~~o__
IXL2Relax
>>>> Build & Ride Reports Are Here <<<<
Reference the XLForum Sportsterpedia
