0 Easy start cam choice
0 Help & advice needed
Last Post: smokey 2
0 1979 iron head sportster exhaust
Last Post: bill smith
0 Wire wheel hubs
Last Post: LenC
0 teflon buttons or circlips?
Last Post: thefrenchowl
0 Single fire dual fire ignition
Last Post: The Doctor71
0 Sources for new/used cast front wheels
Last Post: speedyrette
0 2008 xl1200c
Last Post: Tyler45
0 The Strociek Project
0 Best head casting for porting Question
0 Upper Support Bracket Installation
0 Where To Get Free Air
Last Post: RockerRider
0 My 99 883 c
Last Post: 99-883-c
Last Post: IvanIron
0 Engine oil getting into primary help
Last Post: andy2175m4
0 Timing question
0 Chevelle's Dry Clutch Worm Gear Upgrade
Last Post: Monte03
yeller1200, IronMick (79), painter (72), motobob883 (69), rickxx (67), MRCLEEN (49), Wetcheez (48), hello_shoes (41)
Len PA Len PA is offline
Sportster/Buell Year: 1971
Len PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud ofLen PA has much to be proud of
Default points cam
I am having trouble keeping the same points gap on both lobes of the points cam on my 71 sportster. The best I can do is 22 on the big lobe(rear cylinder) and 18 on the small lobe (front cylinder). The bike runs fine and I am reluctant to mess with it. Just wondering if any one else has come across this. I am using the later style points cam pt. 32542-70A replacing pt. 32542-70.
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
You've had this bike since 1971.... so has it always been this way ? Probably not, but I had to ask.
Anyway, certainly sounds like something is running non-concentric. But what ?
I have not had that problem on either my '71 or '74. If I did, where would I start ?
  • first, I'd ask myself a few questions:
    • so when did this problem first raise its head ?
    • what changed ?
  • then I'd have a look at:
    • the long #10-32 mounting bolt / screw. Is it straight ? is the head square to the shank of the bolt ?
    • BOTH roll pins on the mechanical advance unit. Are they straight ? Does the backside roll pin hang up (aka fail to seat properly) on the notch in cam # 2 ?
    • is the long neck on the mechanical advance unit square to its base ?
  • is the narrow lobe on your points cam just wore out on that side ? (do you have access to a dial indicator?)
Or is there something else going on ?
Sorry Len, just questions, no answers.
RicThompson RicThompson is online now
Sportster/Buell Year: 1969
Len there is no way the bike runs "fine" with a worn out or improperly installed ignition advance unit. You can remove it inspect and re-install or install a new replacement in the comfort of your garage or on the side of the road in the middle of nowhere. Procrastinating will only lead to inconvenience.
mikethebike61's Avatar
mikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond reputemikethebike61 has a reputation beyond repute
Check the dowel pin.....really easy to press it in and have cam off kilter....
I could be wrong....I'll ask the wife....she ALWAYS knows when I'm wrong......
Swamp Biker Swamp Biker is offline
Swamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of lightSwamp Biker is a glorious beacon of light
The 70-78 repair manual (section 5, last paragraph before coil section) says to loosen the bolt, push the assembly towards the widest gap then re-tighten the bolt. I've done this before and it took a few tries to get the gaps within limits.
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Cam bushing is probably worn. Seen this happen before where settings move around after being dialed in.
Might pull the weights and use a ice pick to see if it wiggles.
Traveled to
Whitewalls's Avatar
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
Exactly!
Ive run into this issue with my '71. Do just like the above paragraph says until you get .018 gap on both lobes.
Kingrabbit's Avatar
Kingrabbit Kingrabbit is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: Honda CB550
Other Motorcycle Year: 1974
Kingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to beholdKingrabbit is a splendid one to behold
A quick inspection of the ignition contact point itself is worth the minute. I had one where the contact just was not pressed properly into the contact arm. So there was visible play where there should have been none. And rough running because it was impossible to gap. Shoddy manufacturing.
that is assuming that the install was not correct.if everything is as it should be then the adv will be shoulder to shoulder with the cam as they are both machined surfaces. can it be cocked, why sure but you can only go shoulder to shoulder so if it is so and you are off, something else is amiss. the actual lobe can be worn if high mileage.
make sure the unit is shoulder to shoulder and then remove lobe assy and check for run out. if she is straight, look to the lobe assy as was mentioned.
