0 Help & advice needed
Last Post: smokey 2
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 1979 iron head sportster exhaust
Last Post: bill smith
0 Easy start cam choice
Last Post: 11B40
0 Wire wheel hubs
Last Post: LenC
0 teflon buttons or circlips?
Last Post: thefrenchowl
0 Single fire dual fire ignition
Last Post: The Doctor71
0 Sources for new/used cast front wheels
Last Post: speedyrette
0 2008 xl1200c
Last Post: Tyler45
0 The Strociek Project
0 Best head casting for porting Question
0 Upper Support Bracket Installation
0 Where To Get Free Air
Last Post: RockerRider
0 My 99 883 c
Last Post: 99-883-c
Last Post: IvanIron
0 Engine oil getting into primary help
Last Post: andy2175m4
0 Timing question
0 Chevelle's Dry Clutch Worm Gear Upgrade
Last Post: Monte03
yeller1200, IronMick (79), painter (72), motobob883 (69), rickxx (67), MRCLEEN (49), Wetcheez (48), hello_shoes (41)
iron883, seized, water damage
Old 6 Days Ago
jsaintmartin jsaintmartin is offline
jsaintmartin is an unknown quantity at this point
Exclamation Is my Engine SEIZED!!!???
Help!
I think my engine is seized. After the hurricane. It wouldn’t turn on now it turns on, but makes this sound when I try to start it:
https://photos.app.goo.gl/6edFQqJXZmToxDtt6
http://https://photos.app.goo.gl/6edFQqJXZmToxDtt6
Please let me know what u think!
Old 6 Days Ago
went under water??
sounds like the solenoid does not have enough juice to pull into the starter contacts.
Old 6 Days Ago
Fivecats's Avatar
Fivecats Fivecats is offline
Sportster/Buell Year: '68
Sportster/Buell Model #2: 1968 XLCH
Other Motorcycle Model: '89 FXRS, '73 R50/5
Other Motorcycle Year: '89
Fivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant futureFivecats has a brilliant future
Salt water?
Old 6 Days Ago
shanneba shanneba is offline
Sounds like the starter solenoid is trying to engage the starter.
That can happen with a low battery state of charge.
Your second ink didn't work, there is an extra Http:// at the front and the actual link is missing a : after the correct https
try this one
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 6 Days Ago
Fivecats's Avatar
Check both cables, both ends... Replace the battery.
Old 6 Days Ago
Originally Posted by jsaintmartin View Post
Help!
I think my engine is seized. After the hurricane...
Was it sitting out in the weather during the hurricane? Or garaged/protected?
You might start by charging the battery and seeing if that helps.
Old 6 Days Ago
DTC - Sportsterpedia section on Diagnostic Trouble Codes:
http://sportsterpedia.com/doku.php/t...k:ref:genmsr08
Sportsterpedia Note: The 2007-2009 model years have a significant history of corrosion and gunk collecting in the fuse/relay tray causing low-grade shorts and erratic electrical operation - This is especially problematic if the bike is left outside or operated in the rain. It's a good idea to check & thoroughly clean this tray at least every year (or 4 to 6 months if parked outside)
Sportsterpedia - Check your Starter & Solenoid Assembly (Tests)
For Sportster Tech Info:
Old 6 Days Ago
Yes this motorcycle was left out in the rain, but the battery is definitely charged since i have it on a tender.
I will begin troubleshooting soon
Old 6 Days Ago
Help! I think my engine is seized...
There is the possibility you filled a cylinder with water. Remove the spark plugs, put the transmission in 5th gear and push the bike to see: if the engine will spin, if water spews out a spark plug hole.
If all is well then there's the chronic fuse/relay tray issue etc.
Old 5 Days Ago
Sportster/Buell Year #2: '03
do yourself a favor and check the battery voltage.110 volt devices like the battery tender don't work long in hurricane downpours.
