Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
forward controls, ironhead, xlch
Old 15th May 2011
Originally Posted by chuckseders View Post
Still searching ... Here's another I found:
http://www.narleychoppers.com/media/...9f5c66af_l.jpg (top left) ...
Those are the ones that you want! They are the very best, the Kraft Techs that i referred to in a previous post.
A good buddy here has them on his 1974 with no modifications. Here they are on my 1978 - i made a few mods [Evo shift lever, lowered brake peg, new hole for brake lever, etc] ...
Old 15th May 2011
chuckseders chuckseders is offline
Sportster/Buell Model: Sportster XLCH
Sportster/Buell Year: 1971
Other Motorcycle Model: Honda
chuckseders is an unknown quantity at this point
Excellent! They kinda look like they'll hit my exhaust, but on yours I see they clear behind the pipe instead of in front like the daniel boone kit. Should I expect the same fit even though I've got the right side shift?
Thanks for the attention as I search for these things!
Old 15th May 2011
... Should I expect the same fit even though I've got the right side shift? ...
Yes. They fit my buddies 1974 perfectly, and your 1971 should be the same. Note that mine are a different part number for the left side shift.
Old 16th May 2011
Well narleychoppers.com says these forward controls are out of stock. I just stumbled across Debrix.com which lists a bunch of kits. Here are the ones for the 1957-1974 Sportster starting from the cheapest and going up:
http://www.debrix.com/Wild-Rider-For.../47-304-mw.htm
http://www.debrix.com/Steel-USA-Forw...p/44083-k1.htm
http://www.debrix.com/Forward-Contro...22-0700-vt.htm
http://www.debrix.com/Forward-Contro...p/45861-m1.htm
http://www.debrix.com/Forward-Contro...p/45822-m1.htm
The last two look identical to me and real close to the second link I listed. This makes me think they will also be out of stock because the last one indicates it is out of stock. I don't think they are the daniel boone type. If they appear to be the Kraft tech (or of similar quality) I may try to order them and see what I find out. Here is the page where they are all listed on Debrix.com:
http://www.debrix.com/SearchResults.asp
Sorry about all the links.
Old 17th May 2011
1979XLH 1979XLH is offline
Sportster/Buell Year: 1979
1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough
they work if you can weld. and move the foot pegs(drill a hole). and do alittle garage mods...
look up boone forward control fix you might find something..
i have them.. modified them(took a few hours to get everything right) but they work great now.... just takes some time to set them up.
