0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
clutch, forward controls, shifter
  #31
Old 15th July 2011
Boomer8484's Avatar
Boomer8484 Boomer8484 is offline
Sportster/Buell Year: 1979
Boomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura aboutBoomer8484 has a spectacular aura about
Originally Posted by hasselme0 View Post
these are what I have, don't know if it will help.
Not to get off topic but, where did you get those primary cover plugs.
"Some days, it can take a whole tank of gas to think straight."
Old 15th July 2011
hasselme0 hasselme0 is offline
Sportster/Buell Model: xls roadster rigid
hasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura abouthasselme0 has a spectacular aura about
came with the bike, maybe stock for the xls?
Old 16th July 2011
Originally Posted by headofiron View Post
... I see that your mid control shift arm is positioned down where mine is up could that be causing me problems or does its position not really matter?
Does not matter. Some designs require it up, others down. You really cannot choose once you have a set in hand.
Old 16th July 2011
headofiron's Avatar
headofiron headofiron is offline
headofiron is an unknown quantity at this point
Wow this forum doesn't allow you to do shit...can't post attachments, can't quote messages...Anyway...in response to your last post Mick, I found that out when I tried a few different ways to adjust the shifter on my set up...no matter what way I tried it hit something, not allowing it to push/pull all the way to shift gears...just put it back to mid control and actually found that it's popping out of 2nd when I accelerate...guess I have to look into the clutch/gears now...
Old 17th July 2011
Difficulty getting into gear is typically a clutch problem; slipping out of gear once firmly in is typically a transmission problem.
However, for any of these problems i always check the clutch adjustment first. Easy, no dismantling required. Just follow all of the steps in the factory service manual, or in the Sticky.
Old 18th July 2011
headofiron's Avatar
Thanks Mick...I'm going to give it a try this weekend and see how the adjustment helps.
