Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER & BUELL MOTORCYCLE RACING > Sportster & Buell Motorcycle Racing
Sportster & Buell Motorcycle Racing Talk about racing your Sportster motorcycle and/or Buell motorcycle.
Last Post: mrmom9r
0 Electrical almost all sorted
Last Post: Andy Hog
0 Lurker from the SF Bay Area
Last Post: XL Ed
0 So Long
Last Post: XL Ed
Last Post: xena
0 The Beat Wife
Last Post: Fifty150
Last Post: skien
Last Post: 73HEAD
Last Post: cazz1000
Last Post: jcro61
5 Rethinking 1250 Build
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
  #121
Old 10th June 2014
hcw3 hcw3 is offline
Sportster/Buell Model: xr1200x
Sportster/Buell Model #2: XL1200s
Sportster/Buell Year #2: 1999
Other Motorcycle Model: KTM 450SMR
hcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of lighthcw3 is a glorious beacon of light
Originally Posted by maru View Post
I agree one hundred percent that you should run race gas as insurance against detonation. It does not surprise me that you had it and it is a well known killer of hardware.
It's expensive and I figured it was a stock motor....now the only thing that is is expensive, is the lesson learned.
I hope this was helpful to you. I sometimes come off stronger in www land than in person, but generally I am trying to save folks grief and not create it.
Very helpful. I've been racing a while but HD's are new to me.
Old 10th June 2014
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond repute
Originally Posted by hcw3 View Post
The pipe and intake was made by Tony Bangma at BA Motorsports 616-299-4181. Modest HP, but big torque gain.
Brakes were adequate but weak, I'm using s3 race compound pads from GOLDfren that help, but I wish I had the brakes from my XR1200. Forearm pump from braking wasn't an issue, it's was cold both track days, which helps that. Clutch pull on the other hand is something I will likely have to work on. It's a four finger pull and i really need it to be 1 or 2.
Can't say enough about how much it helps having a great suspension guy, Bruce Blake at Michigan Engineering. Every thing has been sprung and valved for how I ride and and tested on a suspension dyno. Makes the suspension on my XR feel arcane which is saying a lot because the Showa stuff on the XR is quite a bit newer technology.
Next stop is the AHRMA races at Road America 6/7-8.
Replace the cable if its original. I went with a barnett cable, and its a hundred times easier to pull.
Sent from my LG-LS995 using Tapatalk
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 10th June 2014
defnately get the colder plugs as Maru said. The 10R12 HD, NGK is a 9 heat range, Denso is the IXU24. I use the Densos.
Old 12th June 2014
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
Dan, I need to order some of those Densos from you, probably Friday. I need new plugs anyway .
Love is the never-ending act of forgiveness - Peter Ustinov
Old 14th June 2016
Default Still plugging away
I raced the sportster the Last two weekends Gingerman and Road America. Middle to late pack finishes, rider talent or lack thereof is a big limiting factor. Bike has fresh motor, but isn't quite right, i need more rev's. Gonna get some dyno time here soon to look at ignition and fueling.
Old 14th June 2016
Thanks for returning with an update, been awhile, good luck with your racing.
I.B.A.#26543,
Old 11th August 2017
45Brit 45Brit is offline
Sportster/Buell Model: XL
Sportster/Buell Model #2: 1978 XLCH project
Other Motorcycle Year: 1975
45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute
Originally Posted by A 4 liter V8 eater View Post
oh wow, 16.5! I take it you just have to accept that the chain rubs the swingarm pivot. It is very important to adjust the chain tension with the swingarm in the squatted position where the axle, SA pivot, and trans output all line up. In the picture above, the chain looks like it may be tight enough that the first bump will trash the wheel bearings and the trans output bearing.
My stock frame, rigid Evo 883R based Flat Track bike has rubbing strips fitted for that reason. They look like primary chain tensioner shoes bolted to the swingarm..
https://flic.kr/p/WY5bxu
Old 12th August 2017
molochnik molochnik is offline
Sportster/Buell Model: M2; a couple solid-mounts
molochnik is an unknown quantity at this point
hcw3, I'm curious about what kind of rubber you've using. I read through your whole thread and saw you mentioned Avons and some chattering on downshifts...which I suppose happens with any brand.
Are you running stock wheel sizes?
Either way, would you be willing to provide a little insight on what tires/sizes you've tried?
Bike looks good, by the way. I'm considering putting something together with either a 2000 or 2002 frame I've got hanging around (just need to decide which one I want to cut) and a 2000 Buell M2 I rarely ride.
