Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Carb ???
Last Post: andy2175m4
0 2021 Iron Butt Rally
0 Mainshaft Oil Seal Leak
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 First start question
Last Post: 72HOGXLCH
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Old 21st September 2014
18Bravo 18Bravo is offline
Sportster/Buell Model: Infidel Chopper
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Triumph Daytona 675R
Other Motorcycle Year: 2014
18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold18Bravo is a splendid one to behold
Default Mystery Hole
No, not the one Rosie O'Donnell tried to show everyone on the View the other day. (because that's a mystery no one wants to solve)
The issue is this hole on the rear cylinder head of the M2 Cyclone motor I have. I assume it must be for a compression release. If so, why none on the front? And why does my identical year Buell Cyclone motor not have it? I'm wondering if work was done to the motor. The heads are not the same color as the cylinders, as they are on the other motor. Is there a way to tell if they are the Thunderstorm heads? There is a another difference I see. The motor that is still in the bike had a flat surface on it that neither the other Buell motor nor my other two Sportsters have. What is its purpose?
Here's the motor I bought with the hole and heads that appear to be like the other motors. You can see how the head is black, but the cylinder is alminun:
And here's the one that sits in my Buell Cyclone - no hole, and that flat surface on the upper right:
Does it look like someone swapped the heads? Could I have lucked out and gotten a motor someone had work done on to necessitate a compression
release?
I guess I'll find out one way or the other when I tear it down. I had to wait until I had it in its new frame to see if my old '71 Honda tank would clear the motor.
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond repute
It's not a compression release if no air is coming out of it........
If it's a blind hole, my guess is it's for a temperature sensor.
Ed
The Only Y2K dual-set 883C
So Cal
Thanks. That would make sense as I just shined a light into and found it doesn't go all the way through. Curiously enough a cylinder head temperature gauge did cross my mind. I had actually thought of getting one. Any thoughts on the flat portion on the other Buell motor?
Old 23rd October 2014
two sheds two sheds is offline
Sportster/Buell Year: 79
Sportster/Buell Model #2: 79 xlh
Other Motorcycle Model: triumph
two sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of lighttwo sheds is a glorious beacon of light
The hole is for a temp sensor...same heads were used on the fuel injection models (like x-1) the flat spot is just a boss that didn't get machined as the Buell uses a different engine mounting system than a sportster, but started with same head castings. No need to make the hole on the Buell but the spot for it is in the castings for both.
Stocker's Avatar
Stocker Stocker is offline
Sportster/Buell Model: 883L (Well not really)
Other Motorcycle Model: A barn full of bikes
Stocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond reputeStocker has a reputation beyond repute
Looks to me like someone put a set of Buell heads on an 883.
Tom Beckner Tom Beckner is offline
Sportster/Buell Model: XLH 883/HP 1250
Tom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond repute
That's a rear Thunderstorm head, as indicated by the flat boss, matching the
heads I bought new in 2003 or 2003. On mine, down inside there is a threaded
hole for a temperature sensor where a second spark plug would go if you had
it done for dual plugs.
Old 21st November 2014
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
That is a temp sensor hole for the early DDFI Buells. The head was later recalled in favor of an otherwise identical head but with a relocated temp sensor where a second spark plug would go, near the middle of the head. If you're not planning on utilizing the DDFI, it isn't a big deal.
Love is the never-ending act of forgiveness - Peter Ustinov
