Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
Old 3rd November 2014
dawroz dawroz is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1986
dawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nicedawroz is just really nice
Default BUELL xb12 ignition from sportster 1994
Hallo.
I have a problem with my sportster - with Buell XB12 engine inside.
My engine was damaged. I bought 2007 BUELL xb12 engine.
My frame was changed but rest of bike is OEM sportster 1200 - 1994.
Bike is finished now. But don't want work.
Question is:
Does the OEM Sportster 1200 Ignition module with Ign rotor and Ign Timing plate can work buell xb12 engine with stock buell camshafts?
For now - engine does not start.
if you are using stock XB cams you must cut a new timing rotor notch in the cams and you must run a sportser timing rotor not an XB.
I have :
- ignition module from Sportster 1994
- ignition rotor from Sportster 1994
- ignition timing plate from Sportster 1994
- ignition rotor from Buell 2007
- ignition timing plate from Buell 2007
What I have to do with this parts? How I can make a working kit?
you need to cut a new slot for the timing rotor in your #2 XB cam and use the ignition from the 1994 XL.
Hallo again. Ive cut a new slot. Now Im thinking how I can adjust a timing. On crankshaft I have TDC mark only.
To correct adjusting - I need 35 BTDC - yes? (I have original VOES and module from 1200 XL). How can I do it properly?
Old 6th November 2014
Old 22nd November 2014
Hallo again.
I need help with timing. Ive made a new slot in camshaft. Engine works nice. Now Im trying to adjust timing correctly.
I have TDC mark only. How I can adjust timing with strobo. What RPM is the best with TDC mark (without Advance Timing Mark)? Please help.
