Last Post: fafcpa
0 Indicators not flashing
0 Gear indicator missing
Last Post: mrmom9r
0 1975 Sportster
Last Post: IronHeadRon
0 Transmission drain plug
Last Post: mvent
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Gulf Coaster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: SophieWillow
Last Post: 84rzv500r
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: mikethebike61
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
scorcher tires, superlow, tires, xl883l
Old 18th November 2015
darth's Avatar
darth darth is offline
Sportster/Buell Year: 2014
Sportster/Buell Model #2: 1200C/Champion Trike
darth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant future
Been there, done that. A v-twin has quite a bit of torque even at idle... combine that with some grass and it just happens. In my case, I was feathering the clutch at basically idle speed on the grass with the front wheel slightly turned and was on my a$$ before I knew it!
2010 XL1200C (Mine) --- 2009 XL1200C Champion Trike (Hers)
hestersu's Avatar
hestersu hestersu is offline
Sportster/Buell Model: XL883L Superlow
Sportster/Buell Model #2: XL1200N Nightster
hestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of lighthestersu is a glorious beacon of light
Default Dang Scorcher Tires!
Thank you Darth! That's basically what I was doing. That slight change in the front wheel probably brought me down. Just another tool in my toolbox of MC riding. This school of hard knocks is just a tad painful though. I'm a beautiful shade of purple today!
Susan H. My ride: 2014 XL883L Superlow Amber Whiskey "The Beastie"
XLXR's Avatar
XLXR XLXR is offline
Who are you trying to kid? Tires were not the problem, loose nut behind the bars was the real culprit. Hopefully, it is now tightened up a bit.
Welcome to the club, been there, done that, a few times, and last time was at about 40 mph. That's why I were full race quality leathers, full face helmet, racing boots and gloves every time I ride.
Old 19th November 2015
hestersu's Avatar
Saw the doc today. Nothing broken. Just lots of bruising. I think that loose nut behind the bar has been tightened up a notch. ;-) Just need a good riding day to check everything out.
Originally Posted by BKB View Post
There are no street tires that won't scare the crap out of you on grass, tho. lol Heck, even full knob dirt tires will give you a good pucker on grass, if you're not paying attention.
This ^^^^^^^^^^... Grass is more dangerous than ice because we don't think it's nearly that slippery... Keeping the bike upright and balanced is the only way to move it across the grass - slowly & safely...
Glad you're mostly OK... glad to see you're not giving up... every spill can be a learning experience if you make it so... If you're committed to ride, you will probably find more lessons ahead, like we all have...
__o~~o__
IXL2Relax
hestersu's Avatar
I'm committed to learning and riding. I've already made the decision to retake the course in the spring to get my skills up. I love riding and I'm going to continue. I love my little Beastie and can't wait to get back on if the weather will cooperate.
Old 3rd April 2016
dfelt dfelt is offline
Sportster/Buell Model: 1200 xl custom
dfelt is an unknown quantity at this point
Default Scorcher 31's
Glad to hear nothing severely bad happened.Speaking of tires I've got a 13'xlc with 20k km ;front tires only about 1 mm tread left,back are bald.Ya I know not a very good combo.esp.with spring gravel still all over pavement in this area.
Can anyone help with this:My rear is above tire 150/80B16.I put longer shocks on rear and have plenty of clearance to fender.,am wondering about going to a different tire(maybe a radial as opposed to a bias ply w/aramid bc they are slightly lighter/better performing in a sport touring type.Also want to go larger aspect ratio of 150/90.I've read that should give higher gearing which should be ok as I drive like a raped ape usually...lots of longer drives point A to B kinda thing.Speedometer being out I don't care about.
Anybody done this and can take time to give a heads up?Interested about cornering and turn in too.
