Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
Old 30th September 2016
Airbozo's Avatar
Airbozo Airbozo is offline
Sportster/Buell Model #2: S3T Thunderbolt
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XB12R
Other Motorcycle Year: 2009
Airbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond reputeAirbozo has a reputation beyond repute
Default Removing the sprocket rotor assembly
OK, I am stumped. I recently changed my primary oil seal and getting everything off was not an issue. After putting everything back together, the stator failed (no ac out and it failed the "sniff test"). So last night I attempted to tear it apart and for the life of me I cannot remove the sprocket rotor assembly. It just won't budge. It came off pretty easy the first time, but even though it seems to spin freely, I cannot pull it out to get the stator off.
Any suggestions on removing that bugger?
Thanks!
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
Old 4th October 2016
Airbozo's Avatar
Thank to Badweb and BuellXB, I was able to fix this.
Used a cheap puller since the jaws of the expensive one would not fit under the chain.
Now I have to remember not to use so much red locktite as it had flowed onto the splines of the rotor.
lugster's Avatar
lugster lugster is offline
Sportster/Buell Model: xl883r
lugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond repute
I tried to help, posted on your other thread
http://xlforum.net/forums/s...45&postcount=6
Airbozo's Avatar
Saw that Lugster. Tried the 2 jaw but it just wouldn't fit. trying not to muck up the other thread since I posted in the wrong location...
The cheap one would fit under the chain, but kept popping off since it was unbalance. It finally grabbed the chain enough to pull it off. Just had my chain looked at and there was no damage, so I am going to re-use it. Now I have to finish routing the new stator wire.
