Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Mainshaft Oil Seal Leak
Last Post: Bigshankhank
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 Carb ???
0 First start question
Last Post: 72HOGXLCH
Last Post: andy2175m4
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
Old 6th October 2016
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Default Thunderstorm Heads 16827-98YB and 16797-98Y
Can anyone supply an OEM parts list for my heads?
Sent from my Nexus 6P using Tapatalk
Jordan1200
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
Dynatek DC6-5 Single Fire Coul
SE 1340 air cleaner
Bassani Road Rage 2 into 1 Long Exhaust
Old 7th October 2016
ReddTigger's Avatar
This is one, but they're not local.
Twin Motorcycles
States I've Ridden in
71.3 hp 70.8 tq
jordan1200's Avatar
Thanks I just going a copy of a buell parts catalog in PDF format but parts are another story
This from the Hammer Performance website:
http://hammerperf.com/ttxlheads.shtml
98-02 Buell Thunderstorm Heads
Contrary to what you might hear, the springs, retainers, locks, guides, locaters, and valve stem seals are all standard HD pieces in a Thunderstorm head, the exact same part number pieces that you'll find on every other Evolution Sportster and Big Twin head of that era. The Thunderstorm heads do not have any special hardware other than the larger diameter valves.
__o~~o__
IXL2Relax
Reference the XLForum Sportsterpedia
