Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
Old 1st February 2018
sammittrue sammittrue is offline
Sportster/Buell Model: X1 lightening
Sportster/Buell Year: 01
sammittrue is an unknown quantity at this point
Default 01 X1 power and starting issues
So my buddy sold me his X1 for cheap. He said one day it just wouldn't start but run great until that point. The odometer says 22k. Looks pretty clean no oil leaks etc. Turn the ignition on, lights come on and turns/brake signals work but no crank no start. Not even a click. Power at the fuses but I don't really know where to go from here. Having a hard time finding info. If anybody's got a suggestion it'd be much appreciated. Thanks
Old 2nd February 2018
robr's Avatar
robr robr is offline
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Buell X1
Sportster/Buell Year #2: 1999
Other Motorcycle Model: XLCR
Other Motorcycle Year: 1977
robr is an unknown quantity at this point
First make sure the battery is good. If the battery is known to be strong, take off the seat and listen again for the starter relay click. It's a small relay with a low volume click. If no click, they are cheap on Ebay, Amazon or even at an auto parts store.
Battery is brand new and definitely no click. I don't hear the fuel pump out anything. I'll source a starter relay and go from there. Thanks man!
nutter's Avatar
nutter nutter is offline
Sportster/Buell Model: XLH1250
Sportster/Buell Year #2: 1969
nutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to beholdnutter is a splendid one to behold
Check your connections to be sure they are clean and tight. Use a volt meter to check if you have 12 volts on the wire coming from start button to solenoid when you press the start button. check if you have 12 volts from the heavy gauge wire coming from the battery and going to the solenoid. You could jump out the solenoid to determine if the starter is working. If you have 12v on the control wire when start button is pressed and 12 volts at the solenoid it is very likely your solenoid has failed. If you do not have 12v on the control wire I would be tracing the wire backwards until you find it. It is very possible you have a faulty start button.
If you jump out the solenoid make sure you have the bike in neutral!! If you leave it in gear and the starter catches it will lurch and bad things will happen!
Also when checking connections the ground wires need checked also.
Great info. I have not tested the starter button but I have jumped the starter and it works. I'll check the switch and double check the relay tomorrow and update then.
Set trans to neutral, RUN switch on, turn KEY ON - If it works correctly, you should have power for a few seconds with the fuel pump running to prime the line... You should also see the Check Engine Light for those few seconds...
Like Sportsters of the same era, there are two relays - One for the starter & the other a system relay (buell calls it an ignition relay) - You should be able to swap these two to see if the current starter relay will operate in the system relay spot...
These bikes also have a Bank Angle Sensor (BAS) which may cause issues...
I'm not really familiar with these - just passing along some info I gleaned...
Be sure to get a manual...
2 Relax
FREE XLForum Organized Tech Info - Check Out The Sportsterpedia
Definitely no check engine light and definitely no fuel pump noise.
First thing in noticing is sometimes you have to wiggle the key when set to ignition for lights to come on so I'm going to jump the wires at the electrical connector to eliminate the ignition switch. I checked fuses for continuity and visibly they are all good. Only getting power to 2 fuses but I can't find any info on what fuse is what do I can't even describe what fuses other then they are both 15. I found out how to test the starter and ignition relay but adding power to pin 86 and ground to 85 then testing continuity between 87 and 30
Well jumping the three ignition wires solves about 90% of my problems. I have power at every fuse and motor cranks but still won't start. I hear the fuel pump but no nuetral light even when grounding the switch at the connector near sprocket cover.
r4fthrs's Avatar
r4fthrs r4fthrs is offline
Optimist with experience
Sportster/Buell Year: 07
r4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond repute
I had my ignition switch go out on me two years ago and it gave me almost the same symptoms you are describing, but it was intermittent at first. Sometimes it would stall when riding as well. I switched it out (excuse the pun) and all the symptoms went away. I would still check all the other things suggested as it may be a combination of problems.
Armed you are a citizen, unarmed a subject.
Fear the government who fears your guns.
An armed society is a polite society.
