Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 Lurker from the SF Bay Area
Last Post: calileo
Last Post: lehel
5 Rethinking 1250 Build
Last Post: MikeBel
Last Post: mrmom9r
0 Electrical almost all sorted
Last Post: Andy Hog
0 So Long
Last Post: XL Ed
Last Post: xena
0 The Beat Wife
Last Post: Fifty150
Last Post: skien
Last Post: 73HEAD
Last Post: cazz1000
Last Post: jcro61
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
Old 2nd February 2018
Originally Posted by sammittrue View Post
Well jumping the three ignition wires solves about 90% of my problems. I have power at every fuse and motor cranks but still won't start. I hear the fuel pump but no nuetral light even when grounding the switch at the connector near sprocket cover.
The electrics on the early Buells were very similar to the Sportster Sport model... Using many of the same ignition parts...
Check the Bank Angle Switch:
http://sportsterpedia.com/doku.php/t...k_angle_sensor
Make sure you have power on the center pin of the Coil Connector cable (Brief few seconds at Key ON - during the powering of the fuel pump)
Disconnect-Clean-Reconnect the Cam Sensor connection that is under the bike - 3-wire triangular connector...
http://sportsterpedia.com/doku.php/t...osition_sensor
http://sportsterpedia.com/doku.php/t..._testing_spark
2 Relax
FREE XLForum Organized Tech Info - Check Out The Sportsterpedia
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
The common cause of this issue in Buells is the kickstand switch. Some Buell owners carry a paper clip with them so they can bypass it
Click Here to Contact Me
Aaron - Isn't that just to keep the Ignition Relay activated when you try to ride off? The Ignition Relay sounds like it is activated while parked (in Neutral) since the fuel pump runs...
Only _ONE_ of these three is required (right ? ):
Trans in Neutral
Clutch Lever Pulled In
Or Kickstand Up
2 Relax
sammittrue sammittrue is offline
Sportster/Buell Model: X1 lightening
Sportster/Buell Year: 01
sammittrue is an unknown quantity at this point
It's alive!!! Not sure exactly what I did but something worked ha ha. I won't be taking any long adventurous trips yet but hey on the right track. I basically looped the kickstand clutch and nuetral switches. I couldn't get the nuetral light to come on so I just kept scratching my head and wiggling wires and suddenly the nuetral light was staring at me, I hit the start button and it fired right up!
Old 3rd February 2018
Would any of you guys happen to know what other models share the same ignition switch?
Ok so I narrowed down the issues to a faulty kick stand switch and the nuetral switch is intermittent. I think I'll leave the kick stand switch looped permanently but I'll be replacing the nuetral switch. New ignition is $165 bucks but I see a generic round key style 3 wire ignition on Amazon and e bay for $20 I wonder if it will work?
Old 4th February 2018
I'm not sure of the mounting of the Buell switch - but have a look at this recent thread:
http://xlforum.net/forums/s....php?t=2058486
2 Relax
Thanks that was a good read. I think it should work with a little grinder work to make two flat sides on the round barrel. Thanks for the reply. I'll update in a week or so when the part arrives.
