Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 Lurker from the SF Bay Area
5 Rethinking 1250 Build
Last Post: lehel
Last Post: mrmom9r
0 Electrical almost all sorted
Last Post: Andy Hog
0 So Long
Last Post: XL Ed
Last Post: xena
0 The Beat Wife
Last Post: Fifty150
Last Post: skien
Last Post: 73HEAD
Last Post: cazz1000
Last Post: jcro61
0 First start question
Last Post: MikeBel
0 Should I buy a Sportster??
0 Exhaust question
Last Post: Monte03
0 Bassani Baffle Supplier
doughboy (68), tinman (66), mofo (59), JAFI (58), Topgun (56), Hogwylde (56), Pay Toilet (55), grwhite038 (53), JWG883 (52), sorryifitburns (48), Leibniz (46), higgins14 (44)
Old 12th November 2018
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Default How many amps does a 2003 XB charging system create?
Hey guys a question if anyone here knows.. I have a 2003 XB Buell stator and and regulator on my custom build. Does anyone know how many Amps the charging system is rated at.. I think its 32 or 38 amps?
The main breaker on my aftermarket wiring loom is 30 Amps.. is this going to be a problem?
Thanks
I found this online for a 2003 XB9.. Im seeing 34-38 amps charging, and the battery breaker on the XB9 is rated at 30 amps so Im seeing that Im good to go..?
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
You should be good to go.
Old 13th November 2018
Here's the Sportsterpedia section on the Charging System:
http://sportsterpedia.com/doku.php/t...harging_system
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
