Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Electrical and Ignition
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Front deflection
Last Post: denguy
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
Old 8th May 2019
ve6bmw's Avatar
ve6bmw ve6bmw is offline
Sportster/Buell Model: 1200 c
ve6bmw is an unknown quantity at this point
Default My Trixee cranks but no fire
Afternoon people
Here goes,, 05 sportster XL1200C. Had a shop put Love Jugs
and s tach. Rode bike last year with no issues. Put her to bed
for the winter. Went to start her this year and just cranks, will
not start. Now here's my dilemma, the idiot used a type of
pinch connector ( pierced the wire ) on each of the 3 wires
of the coil. Could this be my problem? Broken wires inside casing
because harleys do vibrate.
Old 8th May 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
You can take a look through all the similar threads to see if you can find anything helpful.
Fuel? the same stuff as when you parked it up? Low fuel? try it on reserve. Any fuel in float bowl?
Check for a spark by removing plugs (wet or dry?) and earthing them out.(never spin like this without earthing the plugs).
If it ran ok before then it's more likely to be a fault on the fuel side.
Don't add any engine oil if the tank looks low, it will have sumped due to standing and will return when running.
Old 8th May 2019
Here's the Sportsterpedia section on diagnostcs:
General Diagnostics - Including Won't Turn Over & Won't Start
http://sportsterpedia.com/doku.php/t...k:ref:genmsr01
BUT...
When you're having issues with the electrical system, use this Sportsterpedia section about checking the battery cables, voltages and grounds - DO THIS BEFORE ANYTHING ELSE:
http://sportsterpedia.com/doku.php/t...place_to_start
AND...
Sportsterpedia - Coil Info & Testing
Old 8th May 2019
ve6bmw's Avatar
Fuel is fine and flowing, can smell it. Think it might be the coil, primary side readings came back high
Old 8th May 2019
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
Gotta start with the basics. Fire and fuel. Big question is how old is the gas?
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 8th May 2019
Sportster/Buell Model: XLH883
You could use a hand held indicator on the plug wire to verify if juice is getting to the spark plug.
Old 8th May 2019
ve6bmw's Avatar
Fuel is new, plugs and wires are new, only thing different is how the shop hooked up some
accessories ( Scott packs on the 3 coil wires) so maybe wires broke in casing, also primary resistance is way off. ( secondary readings are good )
Old 8th May 2019
ve6bmw's Avatar
Plugs are wet so fuel is making it to them,, still leaning towards coil issue
due to ohm readings
Old 8th May 2019
Flame__'s Avatar
due to ohm readings
Systematic process of elimination. You got this
Old 8th May 2019
ve6bmw's Avatar
Everything else is good so went and ordered new coil. Now to fix the holes in the 3 wires to coil
