Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER & BUELL MOTORCYCLE RACING > Sportster & Buell Motorcycle Racing
Sportster & Buell Motorcycle Racing Talk about racing your Sportster motorcycle and/or Buell motorcycle.
0 Mainshaft Oil Seal Leak
Last Post: Bigshankhank
0 Indicators not flashing
0 It's Glamazon's Birthday!
Last Post: Veeflys
0 Carb ???
0 First start question
Last Post: 72HOGXLCH
Last Post: andy2175m4
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
Old 22nd May 2019
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Default PMRA Real Street Vtwin
Wanted to share a pretty new class a few others and I have started up.
This is heads up, Dot tire, no bar, foot shifted class.
So far we vary between a 10-15 bike field and looking to grow the numbers to a 25+ bike field. PMRA was been really good to us so far and has brought our class on as a full point class for the 2019 season.
Our requirements are very loose to participate- see attached:
So why you should come race with us:
Stock swing arm/wheel base guys:
There is a $50 purse up from NRHS for top qualifier out of stock swing arm racers for all races , aswell as the top points holder at the end of the season out of stock arm racers will receive a swing arm from Tony Dekergland built to their specs.
Modified guys:
We have a really tight class already, avg times are 9.8-10.2 in the 1/4. Class pay out is 75/25.
We are a street class. So no air/electric shifters, 70" max wheelbase, any cubic inch motor allowed, all makes and models as long as it's a vtwin.
Races are held majority in Tulsa and one race in Noble Oklahoma, so if you are in this region and looking for some of the best Harley racing going on in the area, come join us!
Let me know if you have any questions/ interest and I will be glad to answer what ever I can!
☆Mat Hormell
@Xl90R
Sent from my SAMSUNG-SM-G890A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 22nd May 2019
MatHormell's Avatar
Can a moderator please move this to the drag racing section, meant to post there.
Thank you!
Old 22nd May 2019
MatHormell's Avatar
I suppose I should add some dates..
Race #3 - June 1st @ Tulsa
Race #4 July 13th @ Tulsa
Race #5 Sept 21st @ Noble
Race #6 October 19th @ Tulsa
Old 23rd May 2019
Sprtstr1200s's Avatar
Sprtstr1200s Sprtstr1200s is offline
Sportster/Buell Model: Sportster XL1200s
Sprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond repute
Good luck. Straight up, I don't get it with the no wheelie bar thing. Those are some fine looking bikes. It's safe to assume everyone of those riders has had one stand straight up on them. Why risk health or bike damage.
Old 23rd May 2019
MatHormell's Avatar
1: it's a street class and you cant run wheelie bars on the street
2: it's an equalizer, wheelie bars prevent wheelies.. everytime. That is a major advantage over a guy without them. It removes that variable that is set to equalize the class and make it more about the rider.
Same goes for the air shifters and lock up clutches, have to leave on a hand controlled clutch and foot shift it make it much harder for a huge ci motor build to just dominate the class.
As well as the pro tree, just another equalizer.
And I personally just dont like wheelie bars lol
